    Error on starting MM2: module not present
    22 Posts 2 Posters 10.6k Views 2 Watching
      sdetweil @MWel1977
      @mwel1977 said in Error on starting MM2: module not present:
      Can’t I just remove the MMM-Swipe module and reinstall it?
      sure… but u said that didn’t work before…
      the package.json in MMM-Swipe is looking for electron version 1.2.1, very old…
      I would edit the file before running npm install in the MMM-Swipe folder and chaneg the version to match
      whatever electron verison is installed already…
      MM/node_modules/electron/package.json
      “version”: “2.0.13”
      the MMM-Swipe package.json to
      change
      devDependencies": {
          "electron-rebuild": "^1.2.1"
      to
      devDependencies": {
          "electron-rebuild": "^x.y.z"  === the electron version number above
        MWel1977 @sdetweil
        I think I’ll just start over again with a reimage of the sd card.:persevering_face:
        I’ve checked the package.json file in the electron folder and it showed version 2.0.16
        So I entered that number at the bottom of the package.json file in the MMM-Swipe folder and run npm install again in the Swipe folder. Yet it gave me:
        pi@Mirror:~/MagicMirror/modules/MMM-Swipe $ npm install
        npm ERR! code ETARGET
        npm ERR! notarget No matching version found for electron-rebuild@^2.0.16
        npm ERR! notarget In most cases you or one of your dependencies are requesting
        npm ERR! notarget a package version that doesn't exist.
        npm ERR! notarget
        npm ERR! notarget It was specified as a dependency of 'MMM-Swipe'
        npm ERR! notarget
        npm ERR!     /home/pi/.npm/_logs/2019-01-15T22_09_44_953Z-debug.log
        Thanks for helping me out so far.
        How do you know al this stuff? How long are you already doing this?
        Hope I’ll get that smart one day. :grinning_face:
