    Python in to the magic mirror.
    43 Posts 4 Posters 22.8k Views 4 Watching
      sdetweil
      does your python script continue to run once its started? the design of the node helper starting the script every second depends on the script ending…
      or as you have found you will kill the system (doesn’t matter, pi or larger)…
      you could do it your suggested way… but typically, one would add code in the notification received to start it once…
      • ? Offline
        A Former User @paulvanderheijden90
        You can put var process = spawn("python", ["/home/pi/src/P2000.py"])
        into start function if you want to execute when module is successfully loaded.
        Or you can make some START notification from main module then use it as trigger for execution. You can use socketNotificationReceived function to that purpose.
        Or, you can terminate spawned child process when it becomes needless.
        • P Offline
          paulvanderheijden90 @sdetweil
          Yes one time start the python and it will run.
          • 3 / 3
