    Setting up sleep schedule on laptop question
    1 Posts 1 Posters 592 Views 1 Watching
    • E Offline
      ernenr1
      Hi! I currently have Raspbian Desktop installed on an old Thinkpad x41 tablet in which it runs MagicMirror. Everything is mostly set and ready to go before I mount the laptop on to my wall. The only thing left is to somehow set a sleep schedule. I was wondering what would be the best way to accomplish this?
      I read that people use cron jobs to accomplish this task, but I have a feeling it only works on RasPi’s attached to an external display. Is there any way I can create a cron job to put my laptop in a sleep or suspend state? If that isn’t possible is there any way turn off the LCD display? The laptop will always will be plugged into an outlet. The specs are as listed:
      Architecture:          i686
      CPU op-mode(s):        32-bit
      Byte Order:            Little Endian
      CPU(s):                1
      On-line CPU(s) list:   0
      Thread(s) per core:    1
      Core(s) per socket:    1
      Socket(s):             1
      Vendor ID:             GenuineIntel
      CPU family:            6
      Model:                 13
      Model name:            Intel(R) Pentium(R) M processor 1.50GHz
      Stepping:              8
      CPU MHz:               600.000
      CPU max MHz:           1500.0000
      CPU min MHz:           600.0000
      BogoMIPS:              1197.04
      Flags:                 fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov clflush dts acpi mmx fxsr sse sse2 ss tm pbe nx bts est tm2
