    Downgrade MM
    1 Posts 1 Posters 801 Views 1 Watching
    • A
      Anthony Project Sponsor
      Hello everyone. I would like to ask what problems I may have if I downgrade my MM from latest v. 2.6.0 to v. 2.3.1. I am asking because I have installed MM and Mycroft on the same Rpi 3b+ and the creator of the Magic Mirror Voice Skill suggest this version because of the different versions of electron they use. Last version of MM uses a newer version of electron which causes extremely high CPU usage and will overheat the pi. My pi is in a case with heat sinks and a small fan over the main chip. It does not overheat but it freezes sometimes and I think that it may be electron’s fault. Any idea? Because I am a noob I maybe am wrong so any suggestions will be welcome. Thank you in advance.
