    Combination MMM-Carousel, MMM-OnScreenMenu & MMM-Keybindings
    3 Posts 2 Posters 1.4k Views 3 Watching
    • MondfischM
      Mondfisch
      Hello,
      I have combined the 3 Modules MMM-Carousel, MMM-OnScreenMenu and MMM-KeyBindings.
      But I dont get the Keyboard-Thing…
          			module: 'MMM-KeyBindings',
              			evdev: { enabled: false },
      //        			enableKeyboard: true,
                  		module: 'MMM-Carousel',
                  		position: 'bottom_bar', // Required only for navigation controls
                      			transitionInterval: 10000,
                      			ignoreModules: ['clock', 'alert', 'MMM-OnScreenMenu'],
                      			mode: 'slides',
      					slideTransitionSpeed: 1500,
                      			showPageIndicators: true,
                      			showPageControls: true,
                      			slides: {
                          			main: ['calendar', 'compliments', 'currentweather'],
                          			"Slide 2": ['weatherforecast', 'mvgmunich', 'MMM-AVStock', 'newsfeed'],
                          			"Slide 3": ['MMM-LICE']
                      			keyBindings: {
                          					enabled: true,
                          					map: {
                              				NextSlide: "ArrowRight",
                              				PrevSlide: "ArrowLeft",
                              				Slide0:    "Home",
                          					mode: "DEFAULT"
                  		module: 'MMM-OnScreenMenu',
                  		position: 'bottom_left',
                  		/* Valid positions: 'top_right', 'top_left', 'bottom_right', 'bottom_left' */
                      		touchMode: true,
              			menuItems: {
                  				monitorOff: { title: "Turn Off Monitor", icon: "television", source: "SERVER" },
                  				restart: { title: "Restart MagicMirror", icon: "recycle", source: "ALL" },
                  				refresh: { title: "Refresh MagicMirror", icon: "refresh", source: "LOCAL" },
                  				reboot: { title: "Reboot", icon: "spinner", source: "ALL" },
                  				shutdown: { title: "Shutdown", icon: "power-off", source: "ALL" },
      				enableKeyBindings: true,
      				keyBindingsMode: "OSM",
      				keyBindings: {
      						enabled: true,
      						map: {
      							Up: "ArrowUp",
      							Down : "ArrowDown",
      							Select: "Enter",
      							Close: "Return",
      							Menu: "Menu",
      				kbMultiInstance: true,
      				keyBindingsTakeFocus: "Menu",
                      		menuName: "Main",
      At the Moment, only the OnScreenMenu reacts on pressing the Menu-Key… When I change the “// enableKeyboard: true,” in
      KeyBindings-config, the Carousel reacts on the Arrow-Keys for sliding
      the different Mirror-Screens…
      But I can’t get it to work with BOOTH Modules, ScreenMenu AND Carousel…So when I press left & right Arrow for sliding, while pressing
      Menu/ArrowUp/Down for the Menu and choosing a Option…
      Can anyone point to the right Direction, please?
      Thanx…
      • L
        l0b5ter
        Hi, cant really help here. But do you mind sharing what you did to make MMM-Kebindings work? Im really stuck there :(
        trying to change page based of a key press
        • MondfischM
          Mondfisch
          I’m not sure, wheter Keybindings really works, since only OnScreenMenu reacts on pressing the Menu Key.
          I’ve played around the last Month with Enabling Keybindings in every of the Modules (OnScreenMenu,Key-
          Bindings,Carousel) by changing that… Never got it to work…
          I found out, that the hidden Mousecoursor, when its “over” the Arrows of Carousel, reacts on pressing them.
          So I am able to control them by Mouse, at least…
          the Rest I never get to work together…
          KeyBindings is still Default, as you can see above…
