Volvo on Call
Hello there - I’m discovering the Volvo on Call API and I noticed that Volvo added a screenshot from a MagicMirror on their website. Does anyone knows to whom that belongs?
I tried to install the https://github.com/eouia/MMM-VolvoOnCall but I’m stuck. I’m getting an 401 Error with the message I’m unauthorised. :-/
https://developer.volvocars.com/volvo-api/
I was able to fix the problem with the authorization issue (just reseted my password). So I’m able to pull the information with the python script from https://github.com/molobrakos/volvooncall.
Now I’m getting the following error as soon as I start the Mirror:
[28.02.2022 22:03.38.534] [LOG] [VOC] ERROR: No vehicle found. Check your account. Module stopped.Which is weird because I can pull the data from my car by just typing
voc listorvoc dashboardAny advice would be really appreciated.
@mz-ber
What is your config look like? -
Hey @jerryp - I’m getting the output as soon as I write
voc list. So that seems to work.
My config:
{ module: "MMM-VolvoOnCall", position: "top_right", config: { scanInterval: 1000 * 60 * 30, units: "metric", timestampFormat: "MMM D. HH:mm:ss", durationFormat: "HH:mm", } },@JerryP Can you please share your config? I’m not sure what I’m doing wrong.
@mz-ber
yes but now you miss the data in the configmodule: "MMM-VolvoOnCall", disabled: false, //false, true position: "bottom_left", config: { units: "metric", mapConfig: { apiKey: "", // Your Google Map API Key display: { // You can control which section will be displayed or not. info: false, position: false, status: true, notice: true, trip: false, }}}, -
@jerryp Okay, do I need an api key from google maps?
@mz-ber
yes i’f you use the map function. I have add the api and it’s working fine -
@jerryp is it working for you without the map function? I’m actually not interested in it.
@mz-ber
Yes but i have put the api key in the config. I dont have try it whitout the key -
@jerryp Would you do me a favor and test it without the key or a wrong key? Just wondering if that is the issue
@mz-ber
yes it’s working like above whit out api key -
@jerryp Hi Jerry - thank you for checking! I still stuck and I dont know where I’m doing something wrong. I dont want to give up because I know it is still working for you.
The weird thing is that the API works perfect. I can pull all informations from my car via
voc dashborad.
Only the module is telling me: No vehicle found
That is my current config:
{ module: "MMM-VolvoOnCall", disabled: false, debug: true, position: "top_left", config: { scanInterval: 1000 * 60 * 30, units: "metric", timestampFormat: "MMM D. HH:mm:ss", durationFormat: "HH:mm", display: { info: true, position: true, status: true, notice: true, trip: true, } } },It is setup correctly I guess.
I’m wondering where in this node_helper.js is the
vocpulled from? I’m not good in JavaScript :-(const exec = require('child_process').exec const spawn = require('child_process').spawn const moment = require("moment") var NodeHelper = require("node_helper") module.exports = NodeHelper.create({ start: function() { this.config = null this.carInfo = [] }, socketNotificationReceived: function(noti, payload) { if (noti == "SCAN") { this.scan() this.trip() } if (noti == "INIT") { this.config = payload this.list() } }, list: function() { exec("voc list", (e, sdo, sde)=>{ if (e) { console.log("[VOC] ERROR(>list):", e.toString()) } else { this.listResult(sdo) } }) }, listResult: function(output) { var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm var matches = null var result = [] while (matches = re.exec(output)) { this.carInfo.push({ id: matches[1], type: matches[2], vin: matches[3] }) } if (this.carInfo.length > 0) { this.sendSocketNotification("INITIALIZED", this.carInfo) } else { console.log("[VOC] ERROR: No vehicle found. Check your account. Module stopped.") } }, scan: function() { exec("voc dashboard", (e, sdo, sde)=> { if (e) { console.log("[VOC] ERROR:", e.toString()) } else { this.scanResult(sdo) //this.sendSocketNotification("RESULT", sdo) } }) }, scanResult: function(output) { var carIndex = this.carInfo.map((value, index, array)=>{ return value.id }) var result = [] var re = /^([^\s]+)\s([\w\s]+)\:\s(.+)$/gm var matches = null while (matches = re.exec(output)) { var idx = carIndex.indexOf(matches[1]) var key = matches[2].trim() var value = this.reformValue(key, matches[3].trim()) if (typeof result[idx] == 'undefined') { result[idx] = [] } result[idx].push({ id: matches[1], key: key, value: value }) } if (Object.keys(result).length == 0) { console.log("[VOC] ERROR: No information could be retrieved.") console.log(output) } else { this.sendSocketNotification("SCAN_RESULT", result) } }, reformValue: function(key, value) { if (key == "Position") { var re = /([0-9\.\-]+)\,\s([0-9\.\-]+),\s\'([^\']+)\'/ var matches = re.exec(value) if (matches) { return { lat: matches[1], long: matches[2], time: moment(matches[3]).format("X") } } else { return null } } if (key == "Fuel level") { return value.replace(/\s/, "") } if (key == "Fuel amount" || key == "Range" || key == "Odometer" || key == "Average speed") { return value.replace(/[^0-9\.]+/g, '') } if (key == "Fuel consumption") { var re = /^([0-9\.]+)/g var matches = re.exec(value) if (matches) { return matches[1] } } return value }, trip: function() { for(var i = 0; i < this.carInfo.length; i++) { try { carId = this.carInfo[i].id var sdo = "" var result = spawn('voc', [ '-i', carId, '--json', 'trips' ]) result.stdout.on('data', (data)=>{ sdo += data }) result.on('close', (killcode)=>{ this.tripResult(carId, JSON.parse(sdo)) }) } catch (e) { console.log("[VOC] ERROR:", e.toString()) } } }, tripResult: function(carId, obj) { if (Array.isArray(obj) && obj.length > 0) { var trip = obj[0] var detail = trip.tripDetails[0] var ret = { title: trip.name, category: trip.category, note: trip.userNotes, fuelConsumption : detail.fuelConsumption, electricalConsumption : detail.electricalConsumption, electricalRegeneration: detail.electricalRegeneration, distance: detail.distance, startTime: moment(detail.startTime).format("X"), startPosition: detail.startPosition, endTime: moment(detail.endTime).format("X"), endPosition: detail.endPosition, } this.sendSocketNotification("TRIP_RESULT", {id:carId, data:ret}) } else { return } } }) -
list: function() { exec("voc list", (e, sdo, sde)=>{ if (e) { console.log("[VOC] ERROR(>list):", e.toString()) } else { this.listResult(sdo) } }) },then the good results are parsed in listResult()
@sdetweil Thank you Sam! Can you please tell me what the letters in the bracket mean?
(e, sdo, sde) -
@mz-ber Oh I guess I understand. If the function is not getting the right details than ->
eif everything is okay than ->sdo -
@mz-ber exec(“voc list”, (e, sdo, sde)=
execs the command “voc list”
and the exec function returns
error (e)
stdout (sdo)
and stderr(sde)so if no error (e is null)
it sends the command output to the listResults function
@sdetweil Thank you for the explanation. Is the function executing
voc listin the terminal? If I’m doing manuallyvoc listI’m getting a result.Is there a way to see what the script is getting back in detail?
Again, thank you very much!
@mz-ber yes executing just like on console
nothing built in to show results.
but you could add a
console.log(sdo)
before the call to listResults()
and see it where u start mm
npm startit should be the same outout
@sdetweil Alright, I added the console.log before the call
listResult()and it is getting the details from my car. I feel sooo close to get this running but I dont know where it is stuck. :anguished_face:
Is maybe the regex search not getting the details viewed?
listResult: function(output) { var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm -
@mz-ber so the regular expression isn’t finding your text
/^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gmI use this for building and testing rejects
