    Every few hours I get "ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service"
    36 Posts 4 Posters 12.3k Views 4 Watching
      sdetweil @TvE
      @tve https://www.raspberrypi.com/software/operating-systems/
      scroll down
      • T Offline
        TvE @sdetweil
        Test is now started on legacy PI OS - so by tomorrow I’ll know if I have a stable setup
        • Goal 1 = 4 h (my shortest runtime with bullseye)
        • Goal 2 = 16 h (my longest runtime with bullseye)
        • Goal 3 = 24 h (if I get here I can expect that it’ll continue for ever :-) )
        • T Offline
          TvE @TvE
          Hmm - still unstable
          After just 1,5 hours I get the same error
          [1229:0301/105243.836236:ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service.
          Start test at 08:28
          [01.03.2022 08:28.26.868] [LOG]   Starting MagicMirror: v2.18.0
          Problem kicks in at 10:52
          [01.03.2022 10:52.43.788] [LOG]   Shutting down server...
          Could it really be problematic that I have configured both wlan as well as the eth interface??? (that would be hard to accept…)
          Currently I am using eth, but prepared wlan as that’s what I’ll use when I “go to production”.
            sdetweil @TvE
            @tve well, address:“0.0.0.0”
            means listen on ALL interfaces.
            I use it on my pi w both enabled, but only Ethernet connected. ( and wifi not configured)
            never has ‘crashed’
            you could change to just the ethernet address
            address:“192.168.?.?”
            whatever that address is.
            ifconfig
            will show u
            or
            ip addr
            • T Offline
              TvE @sdetweil
              @sdetweil OK - good point, that’s worth trying
              New test has started only listening on one IP :-)
              • T Offline
                TvE @TvE
                Hmm crashed after 6,5h with the same error…
                NB.: My symptom is the same as being reported here (though I’m not using a docker container)
                https://github.com/electron/electron/issues/31675
                Is there any way of increasing the verbosity in any logs to get more debugging info?
                I’m now perforing a new test:
                • Reverting to the default MM config
                • And tcpdump’ing the network traffic so I can correlate and maybe identify what triggers the network service crash
                If it no longer crashes I’ll revert to my own config and retest (as it then must be related to that specific network traffic [no matter how unfair that seems]
                • T Offline
                  TvE @TvE
                  Test with default config looks good 11h without a crash
                  [02.03.2022 07:43.20.529] [LOG]   Starting MagicMirror: v2.18.0
                  [02.03.2022 18:35.01.238] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                  And still running
                  Thus I must deduce that one of the two services I had configured was triggering the problem
                  I must enable my two changes individually to identify which is “bad”
                    sdetweil @TvE
                    @tve weird
                    • T Offline
                      TvE @sdetweil
                      @sdetweil Yep (but I get exposed to that type of behavior daily :-) )
                      I have also found the DEBUG setting in the conf file:
                      logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"], // Add "DEBUG" for even more logging
                      And am tcpdumping the traffic as well
                      sudo tcpdump -i wlan0 -w tcpdump-wlan.pcap && sudo tcpdump -i eth0 -w tcpdump-eth.pcap &
                      So let’s see what a bisect approach to disabling the “services” leads to
                        sdetweil @TvE
                        @tve yeh, sorry on debug. lots of calendar stuff
                        • T Offline
                          TvE @sdetweil
                          @sdetweil Don’t worry about “debug” I just had to read the config in stead of skipping over that part
                          I have now reverted to my original config and will enable the different service in bisect style.
                          TvE test log (on legacy OS)
                          Re-configured services resulting in crash:
                            1 calendar
                            2 openweather_current
                            3 openweather_forecast
                            4 news
                          A: Sample config
                              => 11h and still OK
                          B: Enable DEBUG log level
                          C: Disable 2+3 (openweather) Enable 1+4
                              => 14 h and still OK
                          D: Enable 2+3 (openweather) + disable 1+4 (news & calendar)
                              => ongoing
                          So in a few days I should know what’s triggering the issue…
                          • T Offline
                            TvE @TvE
                            Hmm so my latest config ran for more than 2 days.
                            I’m now reverting to the initial config (enabling all four config-changes) and then time will tell
                            • T Offline
                              TvE @TvE
                              @sdetweil This is really getting intersting - I have now re-enabled all the config changes so I’m back to my initial config and have been running for four days without a problem.
                              I even reproduced the problem on two differerent physical Pi’s (to eliminate HW) before starting to dissect the config…
                              So for now I can only conclude that something external was triggering these crashes!
                              I can now go back to the latest OS and start adding more stuff to my config (and keep my fingers crossed that I no longer encounter what-ever it was…)
                              Thank you for your help!
                                sdetweil @TvE
                                @tve interesting. keep us informed…
                                • thgmirrorT Offline
                                  thgmirror
                                  @TvE Do you use some wires at the GPIO? For example a PIR-sensor? Than may be interferences causes the issue when an electronic device is around your PI.
                                  Or it is the temperature? Check it with
                                  vcgencmd measure_temp
                                  • T Offline
                                    TvE @thgmirror
                                    @sdetweil Will do!
                                    @thgmirror Nope no PIR sensor (as in “not yet”)
                                    My setup is as basic “Hello World!” as it can be (IMHO)
                                    (The full config can be seen - as a diff to the sample - earlier in this thread)
                                    The pi have been placed horisontally on my desk during all this testing.
                                    It is in a cabinet though (the one from the “startet kit”).
                                    I have measured the temperature (with my hand) and not been alarmed
                                    Now I can validate my assumption based on your tip, thanx!
                                    pi@mirror:~ $ vcgencmd measure_temp
                                    temp=63.4'C
                                    I have read that it’s possible to get add a cooling fin to the CPU, which is something I’ll look in to later (as I am also working on making a replacement for this guy, an image grabber [1].
                                    You can no longer purchase it (and I can make more captures pr second on my pi) for 1/2 the price, I only need to add this thingy [2]
                                    I have HelloWorld! for this, I “just” need to add
                                    • Capture to RAM disk in stead of USB
                                    • Auto upload to an ftp share (or maybe change this to scp…)
                                    • Maybe get the pi’s to netboot as well (as I need 10+ of the system)
                                    But that’s completely irellevant to my MM problem ;-)
                                    [1 ]https://www.epiphan.com/wp-content/uploads/2014/07/epiphan-vga2ethernet-brochure.pdf
                                    [2] https://www.epiphan.com/products/avio-4k/
                                    thgmirrorT 1 Reply Last reply Reply Quote 0
                                      thgmirror @TvE
                                      @tve 63.4 C? Could be less!
                                      You can generate a simple protocol by using
                                      crontab -e and enter
                                      @reboot echo “---------- start ----------” >> proto.txt
                                      */5 * * * * date >> proto.txt
                                      1-56/5 * * * * vcgencmd measure_temp >> proto.txt
                                      which will write a timestamp and a celsius amount every 5 minutes…and an eyecatcher at every boot. Look after a while into the file.
                                      T 2 Replies Last reply Reply Quote 0
                                      • T Offline
                                        TvE @thgmirror
                                        @thgmirror A cron based measuring is a good approach I’ll keep that in mind if I start to suspect temperature (or when I perform a load test my grabber-PI).
                                        For now I do not think it can be temperature related as it’s very reliable around 60 degrees centigrade
                                        temp=59.6'C
                                          sdetweil @TvE
                                          @tve but see his post
                                          https://forum.magicmirror.builders/topic/16485/temperature-of-a-rpi3
                                          60 is bad if u can do 30!
                                          • T Offline
                                            TvE @sdetweil
                                            @sdetweil said in Every few hours I get "ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service":
                                            Great post(!)
                                            (And here I thought that 60 was the normal/expected working temperature)
                                            I think I’ll add a passive solution (or maybe even an active - but then there is a fan that will die)
                                            (I have some other - rather expensive - equipment that died due to a dead fan, and unfortunately there was no way to measure the temperature - bad design…)
                                            I see these two obvious options:
                                            • https://uk.rs-online.com/web/p/raspberry-pi-hats-add-ons/8679039
                                            • https://uk.rs-online.com/web/p/raspberry-pi-hats-add-ons/2020449
                                            The active solution might even add enough cooling even when the fan dies (as it seems that there is a passive “path for the heat” from the CPU
                                            I should try both :-)
                                            What is to gain?:
                                            I am aware that the warmer the chip the shorter it’s life
                                            (I have complained to a vendor that one of their products got so warm that I burn myself if I touch the enclosure, but they insist that it’s expected - even though I have had to get at least three of my nine devices replaced!
                                            I think it’s due to a bad design - hence my heat complaint…)
                                            The rule of thumb is something like this:
                                            By increasing the device temperature by just 10°C, we have reduced the lifetime by over 2x
                                            Sources:
                                            https://jetcool.com/post/semiconductor-lifetime-how-temperature-affects-mean-time-to-failure-device-reliability/
                                            https://www.electronics-cooling.com/2017/08/10c-increase-temperature-really-reduce-life-electronics-half/#:~:text=If one were to ask,reduces component life by half”.
                                            BTW: I have not seen any more network-service-instance-crashes, it’s still going strong after 8 days, really weird (but good!)…
