    Calendar module shows entries outer range
    12 Posts 2 Posters 2.4k Views 2 Watching
      Monkye @Monkye
      And here a picture - SORRY german only
      The Lines marking the events out of date range
      red: december
      blue: august
      yellow: july
        sdetweil @Monkye
        @monkye but those say Friday and Sunday…
        show me the vevent from the ics
        use the url
        curl -sL url >somfile.ics
        then edit the ics w a text editor, it’s just a text file
        each event does
        BEGIN:VEVENT
        END:VEVENT
          Monkye @sdetweil
          @sdetweil Can I sent you a board mail?
            sdetweil @Monkye
            @monkye u can send text to my email. same userid at gmail
              Monkye @sdetweil
              @sdetweil I sent you the mail to your account. Thank you in advance
                sdetweil @Monkye
                @monkye thanks for the ics file…
                reviewing the events, this is a bug in the RRULE processor the calendar module uses
                but not our code
                https://github.com/jakubroztocil/rrule/issues/275
                if you remove the BYMONTHDAY=11
                RRULE:FREQ=YEARLY;WKST=MO;INTERVAL=1;BYMONTHDAY=11
                then it works as expected
                just for info, this issue was opened on Sep 5, 2018 and has not yet been fixed
                so I am not hopeful on a more timely resolution
                  Monkye
                  Many, many THANKS to you. I‘m happy that you resolve this problem
                    Monkye @Monkye
                    Workaround:
                    A little script solve the problem. In the ICS-file at HOME directory will the „BYMONTHDAY“ part deleted.
                    sed -r 's/INTERVAL=1;BYMONTHDAY=[0-9][0-9]?/INTERVAL=1/g' /
                    ~/mycalendar.ics
                      sdetweil @Monkye
                      @monkye nice!
