    Calendar module shows entries outer range
    12 Posts 2 Posters 3.1k Views 2 Watching
      sdetweil @Monkye
      @monkye can you paste the cal config here
      make the url xxxxx
      remember to use the code block markers
      M 1 Reply Last reply
        Monkye @sdetweil
        @sdetweil No problem, the url’s are not a secret :-).
        	position: "top_left",   // This can be any of the regions. Best results in left or right regions.
        	fetchInterval: 240000,
        		maximumNumberOfDays: 30,
        		maximumEntries: 10,
        		getRelative: 0,
        					symbol: "birthday-cake",
        					url: "http://localhost:8080/modules/default/calendars/1.ics",
        					symbol: "calendar-check-o",
        					url: "https://www.zaoe.de/ical/8231/_1-3-4-6/23/"
          Monkye @Monkye
          And here a picture - SORRY german only
          The Lines marking the events out of date range
          red: december
          blue: august
          yellow: july
            sdetweil @Monkye
            @monkye but those say Friday and Sunday…
            show me the vevent from the ics
            use the url
            curl -sL url >somfile.ics
            then edit the ics w a text editor, it’s just a text file
            each event does
            BEGIN:VEVENT
            END:VEVENT
              Monkye @sdetweil
              @sdetweil Can I sent you a board mail?
                sdetweil @Monkye
                @monkye u can send text to my email. same userid at gmail
                  Monkye @sdetweil
                  @sdetweil I sent you the mail to your account. Thank you in advance
                    sdetweil @Monkye
                    @monkye thanks for the ics file…
                    reviewing the events, this is a bug in the RRULE processor the calendar module uses
                    but not our code
                    https://github.com/jakubroztocil/rrule/issues/275
                    if you remove the BYMONTHDAY=11
                    RRULE:FREQ=YEARLY;WKST=MO;INTERVAL=1;BYMONTHDAY=11
                    then it works as expected
                    just for info, this issue was opened on Sep 5, 2018 and has not yet been fixed
                    so I am not hopeful on a more timely resolution
                      Monkye
                      Many, many THANKS to you. I‘m happy that you resolve this problem
                        Monkye @Monkye
                        Workaround:
                        A little script solve the problem. In the ICS-file at HOME directory will the „BYMONTHDAY“ part deleted.
                        sed -r 's/INTERVAL=1;BYMONTHDAY=[0-9][0-9]?/INTERVAL=1/g' /
                        ~/mycalendar.ics
                          sdetweil @Monkye
                          @monkye nice!
