    Calendar module shows entries outer range
    12 Posts 2 Posters 3.1k Views 2 Watching
      Monkye @sdetweil
      @sdetweil No problem, the url’s are not a secret :-).
      	position: "top_left",   // This can be any of the regions. Best results in left or right regions.
      	fetchInterval: 240000,
      		maximumNumberOfDays: 30,
      		maximumEntries: 10,
      		getRelative: 0,
      					symbol: "birthday-cake",
      					url: "http://localhost:8080/modules/default/calendars/1.ics",
      					symbol: "calendar-check-o",
      					url: "https://www.zaoe.de/ical/8231/_1-3-4-6/23/"
      M 1 Reply Last reply
        Monkye @Monkye
        And here a picture - SORRY german only
        The Lines marking the events out of date range
        red: december
        blue: august
        yellow: july
          sdetweil @Monkye
          @monkye but those say Friday and Sunday…
          show me the vevent from the ics
          use the url
          curl -sL url >somfile.ics
          then edit the ics w a text editor, it’s just a text file
          each event does
          BEGIN:VEVENT
          END:VEVENT
            Monkye @sdetweil
            @sdetweil Can I sent you a board mail?
              sdetweil @Monkye
              @monkye u can send text to my email. same userid at gmail
                Monkye @sdetweil
                @sdetweil I sent you the mail to your account. Thank you in advance
                  sdetweil @Monkye
                  @monkye thanks for the ics file…
                  reviewing the events, this is a bug in the RRULE processor the calendar module uses
                  but not our code
                  https://github.com/jakubroztocil/rrule/issues/275
                  if you remove the BYMONTHDAY=11
                  RRULE:FREQ=YEARLY;WKST=MO;INTERVAL=1;BYMONTHDAY=11
                  then it works as expected
                  just for info, this issue was opened on Sep 5, 2018 and has not yet been fixed
                  so I am not hopeful on a more timely resolution
                    Monkye
                    Many, many THANKS to you. I‘m happy that you resolve this problem
                      Monkye @Monkye
                      Workaround:
                      A little script solve the problem. In the ICS-file at HOME directory will the „BYMONTHDAY“ part deleted.
                      sed -r 's/INTERVAL=1;BYMONTHDAY=[0-9][0-9]?/INTERVAL=1/g' /
                      ~/mycalendar.ics
                        sdetweil @Monkye
                        @monkye nice!
