Permission denied after updating node.js and electron
5 Posts 2 Posters 1.3k Views 2 Watching
    SwissChemist
    Hi guys,
    after 1.5 years I thought that it would be time to update my Magic Mirror to version 2.18.0, including node.js and electron.
    But now when I want to start it, I face the following issue:
    magicmirror@2.18.0 start
    sh: 1: ./node_modules/.bin/electron: Permission denied
    I also used Sam’s scripts to update: [https://github.com/sdetweil/MagicMirror_scripts]…but it did not work either.
    Even changing the owner and reinstalling electron did not work:
    pi@raspberrypi:~ $ sudo chown -R pi MagicMirror
    pi@raspberrypi:~ $ npm install electron --unsafe-perm=true
    Has anybody further ideas how to make it work again? Thanks so much!
    @ I have a Raspberry Pi 3 Model B
    S 1 Reply Last reply Mar 20, 2022, 12:45 PM Reply Quote 0
      sdetweil @SwissChemist
      @SwissChemist this sounds like the used up sd card.
      the technology is write once. when the bits are all consumed, the file system does not know, and the result is crazy results.
      sd card is great for low write devices. camera and music player. bad for operating system that uses paging all the time, writing to logs
      S 1 Reply Last reply Mar 20, 2022, 8:59 PM Reply Quote 0
        SwissChemist @sdetweil
        @sdetweil Thanks for the hint!
        I tried to use the same backup on a different SD card, showed the same issue.
        Maybe I need to set it up from scratch on a different card…
        S 1 Reply Last reply Mar 20, 2022, 9:16 PM Reply Quote 0
          @SwissChemist use my backup tool.
          https://github.com/sdetweil/MagicMirror-backup-restore
          is saves config.js, custom.css and the GitHub urls of the add on modules
          then restore adds it all back after mm install
          download and run the backup script.
          save the three files
          then copy back after mm install
          then run restore
          S 1 Reply Last reply Mar 25, 2022, 10:23 PM Reply Quote 0
            @sdetweil Hi Sam,
            thanks very much for your great scripts. They really work like charm!
            Basic installation of the MagicMirror really worked without any issue using your scripts.
            I am just fighting with some modules, which are obviously not up to date, but that’s a different story.
            At least I found the root cause of an issue with MMM_systemtemperature and I hope that I could help some other beginners who struggled with that module and did not get support in corresponding forum up to now…or just misunderstood the instructions in the forum.
            I want to thank you so much for the great work you are doing for the MM community!
