    Every few hours I get "ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service"
    36 Posts 4 Posters 14.2k Views 4 Watching
      sdetweil @TvE
      @tve but see his post
      https://forum.magicmirror.builders/topic/16485/temperature-of-a-rpi3
      60 is bad if u can do 30!
      T 1 Reply Last reply
      • T
        TvE @sdetweil
        @sdetweil said in Every few hours I get "ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service":
        Great post(!)
        (And here I thought that 60 was the normal/expected working temperature)
        I think I’ll add a passive solution (or maybe even an active - but then there is a fan that will die)
        (I have some other - rather expensive - equipment that died due to a dead fan, and unfortunately there was no way to measure the temperature - bad design…)
        I see these two obvious options:
        • https://uk.rs-online.com/web/p/raspberry-pi-hats-add-ons/8679039
        • https://uk.rs-online.com/web/p/raspberry-pi-hats-add-ons/2020449
        The active solution might even add enough cooling even when the fan dies (as it seems that there is a passive “path for the heat” from the CPU
        I should try both :-)
        What is to gain?:
        I am aware that the warmer the chip the shorter it’s life
        (I have complained to a vendor that one of their products got so warm that I burn myself if I touch the enclosure, but they insist that it’s expected - even though I have had to get at least three of my nine devices replaced!
        I think it’s due to a bad design - hence my heat complaint…)
        The rule of thumb is something like this:
        By increasing the device temperature by just 10°C, we have reduced the lifetime by over 2x
        Sources:
        https://jetcool.com/post/semiconductor-lifetime-how-temperature-affects-mean-time-to-failure-device-reliability/
        https://www.electronics-cooling.com/2017/08/10c-increase-temperature-really-reduce-life-electronics-half/#:~:text=If one were to ask,reduces component life by half”.
        BTW: I have not seen any more network-service-instance-crashes, it’s still going strong after 8 days, really weird (but good!)…
        • T
          TvE @thgmirror
          @thgmirror
          63.4 C? Could be less!
          I have now added one of these [1] to my RPI 3 and returned it to the enclosure (the “starter kit cabinet”).
          The temperature is now 48-49 degrees centigrade after 30 min usage of MM.
          So it reduces the temperature with ~14K - thats nice (if you don’t mind listening to a spinning fan which is actually fairly loud in at least 2 meters distance)…!
          I’ll try passive cooling later…
          Oh! - and I had a 14 day uptime before powering off (the original reason for this thread :-)
          [1] https://uk.rs-online.com/web/p/raspberry-pi-hats-add-ons/2020449
            sdetweil @TvE
            @TvE said in Every few hours I get "ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service":
            nice!!
            • T
              TvE @sdetweil
              @sdetweil Yeah - that’s perfect (and expected)
              I really have (now stopped) wondering what happened initially :-)
              @thgmirror
              I made a quick test where I have removed the power to the fan to see how much that changes the temperature (aka a passive cooling test).
              • After ca. one hour the temperature rises to a max of 57-58 degrees centigrades
              • For the next hour the temperature is not rising any more
              • Thus a reduction of ~6K
              NB.: I have now removed the lid to see how big (small) a difference that makes
              • T
                TvE @TvE
                So - without the lid I get another 2K as - after 15 min - the temperature stabilized around 54-55 degrees centigrades
                * Passive cooling lid  on : 63 -> 58 =  -5
                * Passive cooling lid off : 63 -> 55 =  -8
                * Active  cooling lid  on : 63 -> 49 = -14
                * Active  cooling lid off : 63 -> 42 = -21
                thgmirrorT 1 Reply Last reply
                • I
                  Ivanov_d
                  @TvE I am in the same spot as you.
                  Raspberry Pi 3b+
                  Fresh installed Raspbian Bullseye 11
                  Fresh install of MM with vanilla config and modules - crashes every minute and restarts itself. Are you saying that the config might be the problem?
                  0|MagicMirror  | Launching application.
                  0|MagicMirror  | [18725:0322/102613.376542:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                  0|MagicMirror  | [18766:0322/102613.700219:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                  0|MagicMirror  | [22.03.2022 10:26.16.088] [LOG]
                  0|MagicMirror  | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                  0|MagicMirror  | [22.03.2022 10:26.16.175] [LOG]
                  0|MagicMirror  | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                  0|MagicMirror  | [22.03.2022 10:26.16.248] [INFO]
                  0|MagicMirror  | Checking git for module: default
                  0|MagicMirror  | [22.03.2022 10:26.17.014] [INFO]
                  0|MagicMirror  | Newsfeed-Fetcher: Broadcasting 61 items.
                  0|MagicMirror  | [22.03.2022 10:26.17.522] [INFO]
                  0|MagicMirror  | Calendar-Fetcher: Broadcasting 10 events.
                  0|MagicMirror  | [22.03.2022 10:27.33.823] [LOG]   Shutting down server...
                  0|MagicMirror  | [22.03.2022 10:27.33.833] [LOG]   Stopping module helper: updatenotification
                  0|MagicMirror  | [22.03.2022 10:27.33.835] [LOG]   Stopping module helper: calendar
                  0|MagicMirror  | [22.03.2022 10:27.33.848] [LOG]   Stopping module helper: newsfeed
                  0|MagicMirror  | [18692:0322/102733.909781:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                  0|MagicMirror  | [18692:0322/102733.942607:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                  0|MagicMirror  | [18692:0322/102733.958362:ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service.
                  0|MagicMirror  | [18692:0322/102733.974458:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                  0|MagicMirror  | [18692:0322/102733.982862:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                  0|MagicMirror  | [18692:0322/102733.989821:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                  0|MagicMirror  | [18692:0322/102733.998527:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                  0|MagicMirror  | > magicmirror@2.18.0 start
                  0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                  0|MagicMirror  | [22.03.2022 10:27.42.385] [LOG]
                  0|MagicMirror  | Starting MagicMirror: v2.18.0
                  0|MagicMirror  | [22.03.2022 10:27.42.407] [LOG]
                  0|MagicMirror  | Loading config ...
                  0|MagicMirror  | [22.03.2022 10:27.42.421] [LOG]
                  0|MagicMirror  | Loading module helpers ...
                  0|MagicMirror  | [22.03.2022 10:27.42.427] [LOG]
                  0|MagicMirror  | No helper found for module: alert.
                  0|MagicMirror  | [22.03.2022 10:27.42.463] [LOG]
                  • thgmirrorT
                    thgmirror @TvE
                    @TvE That is my experimental setup:
                    • T
                      TvE @Ivanov_d
                      @Ivanov_d
                      Maybe we’re observing the same - currently it’s hard for me to tell.
                      • You surely have no heat issue (no additional cooling is needed - only to prolong the life of the RPI)
                      • OS
                        As you hopefully have read in this thread I started with the same OS as you, then “downgraded” to the socalled “legacy” version and still saw the issues. then it suddenly stopped.
                        Thus I need to replace to the latest OS and retest
                      I have no logical reason to suspect the OS but I need to do the test to be 100% certain…
                      • You can follow my test steps (using bisection - remove the handfull of external calls and see which triggers the problem)
                      • My guess
                        So far I can only conclude that something external provoked the network stack to crash.
                        In the end of my testing () I had returned to my original config and no longer see problems
                        That something must relate to one of the two services I was using (part of the vanilla config)
                      UPDATE!!! - I just looked at my test and wow, this morning I had an error again (my test runs with the monitor turned off, thus I did not see this (I’m working on other tasks at the moment…).
                      Looking in the logs I see calendar related issues a few hours before the service stopped
                      My error occurred at [21.03.2022 22:39.02.219] in Denmark
                      Your error occurred at [22.03.2022 10:27.33.823] in US? (guess deduced from your config)
                      That way too close to just be a coincidence…
                      I don’t know for how long you have been running your system, but I will now start to suspect that the root cause lies in the calendar service and we both are affected by the same root cause
                      I wonder if we can find another source for those data
                      (I now regret that I turned of tcpdump for my latest testing…)
                      stdout
                      [21.03.2022 22:34.06.084] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                      [21.03.2022 22:39.02.219] [LOG]   Shutting down server...
                      [21.03.2022 22:39.02.225] [LOG]   Stopping module helper: updatenotification
                      [21.03.2022 22:39.02.226] [LOG]   Stopping module helper: calendar
                      [21.03.2022 22:39.02.227] [LOG]   Stopping module helper: newsfeed
                      err
                      [21.03.2022 16:43.52.620] [WARN]  ^[[33mYou're using a full whitelist configuration to allow for all IPs^[[39m
                      [1002:0321/164356.019064:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                      [1040:0321/164356.860589:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                      [21.03.2022 17:37.30.487] [ERROR] Calendar Error. Could not fetch calendar:  http://calendars.icloud.com/holidays/dk_da.ics FetchError: request to https://calendars.icloud.com/holidays/dk_da.ics failed, reason: connect ETIMEDOUT 17.248.150.146:443
                          at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1483:11)
                          at ClientRequest.emit (node:events:394:28)
                          at TLSSocket.socketErrorListener (node:_http_client:447:9)
                          at TLSSocket.emit (node:events:394:28)
                          at emitErrorNT (node:internal/streams/destroy:157:8)
                          at emitErrorCloseNT (node:internal/streams/destroy:122:3)
                          at processTicksAndRejections (node:internal/process/task_queues:83:21) {
                        type: 'system',
                        errno: 'ETIMEDOUT',
                        code: 'ETIMEDOUT'
                      [21.03.2022 17:44.40.539] [ERROR] Calendar Error. Could not fetch calendar:  http://calendars.icloud.com/holidays/dk_da.ics FetchError: request to https://calendars.icloud.com/holidays/dk_da.ics failed, reason: connect ETIMEDOUT 17.248.150.10:443
                        type: 'system',
                        errno: 'ETIMEDOUT',
                        code: 'ETIMEDOUT'
                      [958:0321/223902.258167:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                      [958:0321/223902.279012:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                      I 1 Reply Last reply
                      • I
                        Ivanov_d @TvE
                        @TvE it’s been running for 25 hours so far:
                        pm2 status MagicMirror
                        │ App name      │ id │ version │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                        │   MagicMirror │ 0  │ 2.18.0  │ fork │ 2911 │ online │ 15      │ 25h    │ 0%  │ 2.7 MB   │ pi   │ disabled │
                        I am still tweaking my config, however, my approach was the following:
                        1. I updated from Rapbian Buster to Bullseye
                        2. That broke my Raspberry Pi 3b+'s WiFi connection (seems like a known bug https://forums.raspberrypi.com/viewtopic.php?t=325484), so I removed connman package and installed network-manager and connected to the WiFi. If you install network-manager, you will also want to disable the MAC randomization:
                          To disable the WiFi MAC randomization, create the following file using the this command:
                        sudo nano /etc/NetworkManager/conf.d/100-disable-wifi-mac-randomization.conf
                        and paste the following content inside:
                        [connection]
                        wifi.mac-address-randomization=1
                        [device]
                        wifi.scan-rand-mac-address=no
                        Save the changes and continue.
                        1. I backed up my MM config and modules folder and started with a fresh install of MM 2.18
                        2. I started MM with the default config - no luck, it was crashing every minute
                        3. I started removing the default modules and installing the ones that I had before
                        4. I was observing the same behavior as you did - the default modules that needed network connection, when fetching data were breaking the network stack somehow … I edited the config to enter my calendar and newsfeed URLs and that seemed to fixed the issue. It might be something in the response of the default calendar and/or newsfeed … but that is just my speculation.
                        I also have pulled all the latest updates for every module that I had installed previously just to make sure that I am all up to date.
                        Ever since as you can see, my MM has been running steadily. Definitely not an SoC temp issue, since I never had anything than the stock aluminum radiators on the Pi and it has been running for 3-4 years 24/7 already.
                        I wouldn’t have decided to upgrade to bullseye if it was not a requirement for the new version of MMM-GoogleAssistant.
                        Anyways, I hope that this helps.
                        P.S. I am in Sofia, so the date/time in my log is GMT +02:00
                        • I
                          Ivanov_d @Ivanov_d
                          @TvE I was jumping for joy way too soon. I took out my SD card to make a backup of it and when I put it back in, MagicMirror started restarting every other minute just like before. No changes were made whatsoever. I am now very confused …
                          • I
                            Ivanov_d
                            Today I got a new error message “GPU process isn’t usable. Goodbye.”:
                            0|MagicMirror  | [25.03.2022 16:21.17.187] [INFO]  Checking git for module: MMM-homeassistant-sensors
                            0|MagicMirror  | [25.03.2022 16:21.17.354] [INFO]
                            0|MagicMirror  | [25.03.2022 16:22.15.459] [LOG]   Shutting down server...
                            0|MagicMirror  | [25.03.2022 16:22.15.464] [LOG]   Stopping module helper: updatenotification
                            0|MagicMirror  | [25.03.2022 16:22.15.466] [LOG]   Stopping module helper: MMM-MyCalendar
                            0|MagicMirror  | [25.03.2022 16:22.15.468] [LOG]   Stopping module helper: MMM-DarkSkyForecast
                            0|MagicMirror  | [25.03.2022 16:22.15.469] [LOG]   Stopping module helper: newsfeed
                            0|MagicMirror  | [25.03.2022 16:22.15.470] [LOG]   Stopping module helper: MMM-GoogleAssistant
                            0|MagicMirror  | [25.03.2022 16:22.15.472] [LOG]   Stopping module helper: Gateway
                            0|MagicMirror  | [25.03.2022 16:22.15.474] [LOG]   Stopping module helper: EXT-Alert
                            0|MagicMirror  | [25.03.2022 16:22.15.476] [LOG]   Stopping module helper: EXT-Detector
                            0|MagicMirror  | [25.03.2022 16:22.15.477] [LOG]   Stopping module helper: MMM-Spotify
                            0|MagicMirror  | [25.03.2022 16:22.15.479] [LOG]   Stopping module helper: MMM-MyCommute
                            0|MagicMirror  | [25.03.2022 16:22.15.480] [LOG]   MMM-GoogleBirthdaysProvider: Stopping helper
                            0|MagicMirror  | [25.03.2022 16:22.15.482] [LOG]   Stopping module helper: MMM-homeassistant-sensors
                            0|MagicMirror  | [16373:0325/162215.558435:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                            0|MagicMirror  | [16373:0325/162215.603817:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                            0|MagicMirror  | [16373:0325/162215.612830:ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service.
                            0|MagicMirror  | [16373:0325/162215.642076:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                            0|MagicMirror  | [16373:0325/162215.660312:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                            0|MagicMirror  | [16373:0325/162215.668549:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                            0|MagicMirror  | [16373:0325/162215.678393:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                            0|MagicMirror  | [16373:0325/162215.685640:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                            0|MagicMirror  | [16373:0325/162215.692769:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
                            0|MagicMirror  | [16373:0325/162215.692890:FATAL:gpu_data_manager_impl_private.cc(417)] GPU process isn't usable. Goodbye.
                              sdetweil @Ivanov_d
                              @Ivanov_d got no idea, but try this from web search
                              edit package.json
                              edit the “start” line
                              after electron add
                              --no-sandbox
                              with a space around it
                              • I
                                Ivanov_d
                                I usually don’t do this and dig to the bottom of the problem, but this time I gave up and reverted back to Raspbian Buster and all my issues were solved. It seems that there are still some issues with RPi3b+ and Bullseye.
                                • D dathbe referenced this topic on
