    Weather not Loading
    4 Posts 2 Posters 1.9k Views 2 Watching
      Cyric
      I upgraded to 2.19, and saw that the weather forecast and current weather both depreciated. I read the migration and made the changes, and now both get stuck at loading.
      Everything else updated fine, and both modules were working before the change. I tried to specify which provider to use instead of the default. i removed the location id and tried to just use location and vice versa. Neither worked.
      Here’s my code, I removed the api key and location data, but it was all fine before the change.
      			module: "weather",
      				type: "current",
      				locationID: "XXXXXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "XXXXXXX"
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				appid: "XXXXXXX"
      Thanks!
        DarrenHill @Cyric
        @Cyric The new module uses apiKey rather than appid in the config. Try changing that in each entry.
          Cyric @DarrenHill
          @DarrenHill
          I’m dumb, that fixed it.
          Thanks!
            DarrenHill @Cyric
            @Cyric - You’re welcome.
            I did the same update myself this morning, so know what needed to be changed…
            Don’t forget to mark the issue as solved.
