    No authorization at command input
    11 Posts 2 Posters 3.5k Views 2 Watching
    • T Offline
      Tavros
      Hello everyone, I get the message “no permission” when I run a command. for example npm run config:check. I have the latest version of Magic Mirror installed and running on a Pi 3b+. Starting the SW works fine. Do you know of a paper on this? do you need more info?
        sdetweil @Tavros
        @Tavros can u show the output of the
        • T Offline
          Tavros
          pi@raspberrypi:~/MagicMirror $ npm run config:check
          magicmirror@2.19.0 config:check /home/pi/MagicMirror > node js/check_config.js
          /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2383 const require$1 = Module.createRequire((typeof document === ‘undefined’ ? new equire(‘u’ + ‘rl’).URL) ('file: filename).href : (document.currentScript & document.currentScript.src || new URL(‘eslintrc.cjs’, document.baseURI).href)) A
          TypeError: Module.createRequire is not a function at Object. (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/
          st/eslintrc.cjs:2383:26)
          at Module._compile (internal/modules/cjs/loader.js:776:30) at Object. Module._extensions…js (internal/modules/cjs/loader.js:787:10)
          at Module.load (internal/modules/cjs/loader.js: 653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12) at Function. Module._load (internal1/modules/cjs/loader.js:585:3)
          at Module.require (internal/modules/cjs/loader.js: 690:17) at require (internal/modules/cjs/helpers.js:25:18)
          at Object.<anonymous (/home/pi/MagicMirror/node_modules/eslint/lib/cli-en
          ne/cli-engine.js:33:5) at Module._compile (internal/modules/cjs/loader.js:776:30)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          I
          npm ERR! magicmirror@2.19.0 config:check: node js/check_config.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.19.0 config:check script. npm ERR! This is probably not a problem with npm. There is likely additional 1 ging output above.
          npm ERR!
          /home/pi/. npm/_logs/2022-04-04T17_07_40_905Z-debug.log
          • T Offline
            Tavros
            sorry couldn’t add a picture. can you read something there?
              sdetweil @Tavros
              @Tavros said in No authorization at command input:
              this is a known issue
              see
              https://github.com/MichMich/MagicMirror/issues/2772
              • T Offline
                Tavros @sdetweil
                @sdetweil thanks i did it. but the message still appears at "config/config.js
                  sdetweil @Tavros
                  @Tavros show the message again
                  • T Offline
                    Tavros @sdetweil
                    pi@raspberrypi:-/MagicMirror S config/config.js bash: config/config.js: Keine Berechtigung
                    pi@raspberrypi:~/MagicMirror $ config/ bash: config/: Ist ein Verzeichnis
                    pi@raspberrypi:~/MagicMirror config.js
                    bash: config.js: Kommando nicht gefunden.
                    pi@raspberrypi:~/MagicMirror $ npm run config: check
                    magicmirror@2.19.0 config:check > node js/check_config.js
                    [04.04.2022 21:58.25.956] [INFO] Checking file /home/pi/MagicMirror/config/config.js
                    [04.04.2022 21:58.26.243] [INFO] Your configuration file doesn’t contain syntax errors :) pi@raspberrypi:~/MagicMirror $
                      sdetweil @Tavros
                      @Tavros you don’t EXECUTE config.js, it is USED by magic mirror
                      npm start
                      you can edit it, just a text file
                      nano config.js
                      T 2 Replies Last reply Reply Quote 0
                      • T Offline
                        Tavros @sdetweil
                        @sdetweil okaaayy i’m a beginner. I’ll try it tomorrow then. Thanks!
                        • T Offline
                          Tavros @sdetweil
                          @sdetweil as works, thank you!
