    Issue with PIR Sensor after upgrade to 2.19
    12 Posts 4 Posters 3.5k Views 4 Watching
    • O Offline
      OliWer
      after upgrading to 2.19 MM is not starting anymore with the following message:
      [07.04.2022 16:30.26.410] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 93. This version of Node.js requires
      NODE_MODULE_VERSION 101. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      [07.04.2022 16:30.26.412] [LOG]   Loading module helpers ...
      [07.04.2022 16:30.26.413] [LOG]   Initializing new module helper ...
      [07.04.2022 16:30.26.415] [LOG]   Module helper loaded: MMM-CalendarExt2
      [07.04.2022 16:30.26.416] [LOG]   No helper found for module: MMM-CalendarExtPlan.
      [07.04.2022 16:30.26.422] [ERROR] App threw an error during load
      [07.04.2022 16:30.26.424] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          at process.func [as dlopen] (node:electron/js2c/asar_bundle:5:1800)
          at Object.Module._extensions..node (node:internal/modules/cjs/loader:1199:18)
          at Object.func [as .node] (node:electron/js2c/asar_bundle:5:1800)
          at Module.load (node:internal/modules/cjs/loader:988:32)
          at Module._load (node:internal/modules/cjs/loader:829:12)
          at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
          at Module.require (node:internal/modules/cjs/loader:1012:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:112:48)
          at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31
      [07.04.2022 16:30.26.425] [ERROR] Whoops! There was an uncaught exception...
      [07.04.2022 16:30.26.430] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31 {
        code: 'ERR_DLOPEN_FAILED'
      I already tried npm install and npm rebuild in the modules folder, but getting an error there as well
      npm ERR! code 255
      npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor
      npm ERR! command failed
      npm ERR! command sh -c node_modules/.bin/electron-rebuild -e ../../node_modules/electron
      npm ERR! - Searching dependency tree
      npm ERR!
      npm ERR! An unhandled error occurred inside electron-rebuild
      npm ERR! Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
      npm ERR!
      npm ERR! Error: Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
      npm ERR!     at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:36:9)
      npm ERR!     at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:126:48)
      npm ERR!     at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:404:23)
      npm ERR!     at Object.doRebuild [as rebuild] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:427:16)
      npm ERR!     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:124:33
      npm ERR!     at Generator.next (<anonymous>)
      npm ERR!     at fulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:6:58)
      npm ERR!     /home/pi/.npm/_logs/2022-04-07T14_35_12_484Z-debug-0.log
      Removing and re-adding the module results in the same issue.
      Thanks in advance!
        sdetweil @OliWer
        @OliWer try this
        npm install node-abi
        then npm install in the module folder
        • O Offline
          OliWer @sdetweil
          I did now, but same issue =(
            sdetweil @OliWer
            @OliWer ok, erase the mode_modules folder in the module folder and the package-lock.json file
            and redo npm install
            • O Offline
              OliWer @sdetweil
              Same…
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall
              ⠋ Searching dependency tree
              npm ERR! code 255
              npm ERR!     /home/pi/.npm/_logs/2022-04-07T15_08_23_853Z-debug-0.log
              karsten13K S 2 Replies Last reply Reply Quote 0
              • karsten13K Offline
                karsten13 @OliWer
                @OliWer
                already discussed here
                  sdetweil @OliWer
                  @OliWer ok, 2 more steps.
                  ok, we are executing electron rebuild from the module folderm, it can’t find the important info about electron in the base folder… SO
                  npm install electron-rebuild --save
                  then cd to the module folder again and then
                  ~/MagicMirror/node_modules/.bin/electron-rebuild
                    sdetweil @karsten13
                    @karsten13 yeh, he just said he wasn’t gonna fix his tool…
                      karsten13 @sdetweil
                      @sdetweil AFAIS someone got it running https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/32?page=4# but don’t know if it works
                        sdetweil @karsten13
                        @karsten13 magicmirror-rebuild does not work for this module…and won’t be fixed
                        (as the module is ‘archived’)
                          karsten13 @sdetweil
                          yes, MMM-PIR-Sensor is deprecated so its better to use another module which is still maintained.
                          I got MMM-PIR-Sensor installed with this workaround:
                          Change dependencies section in package.json to
                            "dependencies": {
                              "onoff": "latest",
                              "magicmirror-rebuild": "latest"
                          Run npm install which will fail.
                          Edit node_modules/epoll/binding.gyp and insert the following in line 2 (after the first {):
                            "variables": {
                              "openssl_fips" : "0"
                          Run npm install again.
                          • O Offline
                            OliWer
                            Thanks for your help =)
                            I was not able to get MMM-PIR-Sensor running, even with your steps listed above. As it is deprecated I did what @karsten13 suggested and used another PIR (MMM-PIR). It had the same issue first, but using magicmirror-rebuild from https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1 I was able to got the PIR working again.
                            So again: Thanks for trying to help and your suggestions!
