    Change Folder of Logs of PM2 and NPM
    11 Posts 2 Posters 5.1k Views 2 Watching
      sdetweil @thgmirror
      @thgmirror you could make a linked folder from their orignal place to /var/log
      see the ln command
      thgmirrorT 1 Reply Last reply Reply Quote 0
      • thgmirrorT Offline
        thgmirror @sdetweil
        @sdetweil Thank you for your reply, but I prefer to store the log-files physically at var/log.
        I currently use var/log as a RAMDisk, because I normally don’t need log-files. So I avoid a lot of write access to the SD-card, it is faster and safer for the SD…and after a reboot, everything is fine:-)
        My attempt is, to do this for npm and PM2-logs, too.
        As far as I know, I can start PM2 with parameters -o and -e and the new foldernames, but they destroyed my installation. Btw., how do you start PM2 in your script? I would like to add the parameters so it is automatically connected after reboot.
        Thomas
          sdetweil @thgmirror
          @thgmirror no… you misunsderstand the point
          make a folder in /var/log where u want them to BE
          then in the users home folder create a ‘fake’ .pm2 folder for the pm2 stuff
          which points to the /var/log folder using the ln command
          the pm2 app will be happy and NEVER know that the REAL location is /var/log
          thgmirrorT 1 Reply Last reply Reply Quote 1
            thgmirror @sdetweil
            @sdetweil Ah, OK, I will give it a try:-)
              sdetweil @thgmirror
              @thgmirror in the users home foder
              # get into the users home folder
              cd ~
              # move the .pm2 folder to /var/log, pick a name
              mv .pm2 /var/log/pm2.real
              # make a link to it from users home folder
              ln -s  /var/log/pm2.real .pm2
              oops, edited ln…
              target <- link
              from /var/log
              drwxrwxr-x 5 sam sam 4096 Apr 9 10:29 .pm2/
              then in home folder
              ls .pm2 will show files
              ls -laF
              will show that .pm2 is a link (and where to)
              lrwxrwxrwx 1 sam sam 13 Apr 9 10:31 .pm2 -> /var/log/.pm2/
                thgmirror @sdetweil
                @sdetweil but you know, a RAMDisk is volatile, I can’t copy something to a RAMDisk in forehand…it is gone after a reboot.
                  sdetweil @thgmirror
                  @thgmirror then u will have to create target folder on boot…
                  note that pm2 stores config info in there too(the jobs it manages) … so it MUST be persistent
                  but you could just link the logs folder from the users real .pm2 folder (the stuff that is volatile…)
                  well, logs are useful but…
                    thgmirror @sdetweil
                    @sdetweil and where is the PM2 start?
                    Of course it must be persistant, but I don’t want to change the location of the PM2-configuration.
                      sdetweil @thgmirror
                      @thgmirror someplace in the .pm2 folder… no idea myself…
                      the .pm2/logs folder I know
                      never examined the others
                        sdetweil @thgmirror
                        @thgmirror and there is a $HOME/.npm folder for npm, but I have no idea what all is stored there, and what needs to be persistent and not
