    MMM-berfex Change font size
    8 Posts 2 Posters 2.1k Views 2 Watching
      rantanplan
      My MMM-berfex runs fine. But I would like a bigger font.
      All attempts to customize the custom.css failed.
      Also in the MMM-berfex.css or MMM-bergfex.js (config.js) no changes helped.
      Does anyone have an idea how I can change the font size of the data?
      Thanks in advance.
      Translated from German with G…
        sdetweil @rantanplan
        @rantanplan I don’t know, but see here on how to use the browser dev window
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486164
          rantanplan
          Thanks @sdetweil,
          this has already helped me to recognize that the font size xsmall is used.
          Now I can adjust the custom.css .
          I would have liked to set the size to “small”, like most of my other modules. That still doesn’t work.
          Translated from the German with G…
            @rantanplan said in MMM-berfex Change font size:
            ok, I am confused… if you can use custom.css then u can make this change
            read this about the css selectors
            you can change the value top right, yes?
            then u know what to change in custom.css (and can do with copy/paste of the info top right)(
              rantanplan @sdetweil
              @sdetweil said in MMM-berfex Change font size:
              But I don´t know how! I can set the font size “xsmall” or “small” to 15.px or 20px. But I want to set the font size “small” where the “xsmall” is.
              Hope you undestand my bad english. :folded_hands:
              Tried without G…translation :face_savoring_food:
                @rantanplan in the upper right, (blue in image below) after you have selected the element u want to change
                type fo
                and u should get a list of ‘styles’ that start with fo and scroll down and select font-size
                then it with put the cursor after the :
                and type small
                and press enter
                you MAY have to add !important to override
                if this does what you want
                then use the mouse to select all in the upper right window
                right click and copy
                open the custom.css in some text editor
                and do , right click , paste
                in the middle pane (red in image below) , there is a item tree
                the right most corresponds to the item u selected
                use that in the css selector
                in calendar (right most column) that is td.time.light
                so the custom.css entry would be
                .modulename selector {
                    styles
                or
                .calendar  td.time.light  {
                     font-size: small;
                  rantanplan
                  OK, I think I’ve got it now.
                  However, I have to connect a large monitor first, I use the official 7" monitor. Too small to work with it.:man_facepalming:
                  Thank you for your help!
                    @rantanplan you can do the debug from your pc, and still have the 7 in be fine
                    in config.js
                    set
                    address:“0.0.0.0”,
                    ipWhiltelist:[],
                    then u can connect to MM from your desktop and debug…
                    hit f5 to reload the pc MM page with the updated css…
                    use the bitvise ssh client, you can edit the files on the pi from your pc… by double click like on the pc
                    (enable ssh on the pi too)
