    MMM-berfex Change font size
    8 Posts 2 Posters 1.5k Views 2 Watching
      sdetweil @rantanplan
      @rantanplan said in MMM-berfex Change font size:
      Now I can adjust the custom.css .
      I would have liked to set the size to “small”, like most of my other modules. That still doesn’t work.
      ok, I am confused… if you can use custom.css then u can make this change
      read this about the css selectors
      you can change the value top right, yes?
      then u know what to change in custom.css (and can do with copy/paste of the info top right)(
        rantanplan @sdetweil
        @sdetweil said in MMM-berfex Change font size:
        But I don´t know how! I can set the font size “xsmall” or “small” to 15.px or 20px. But I want to set the font size “small” where the “xsmall” is.
        Hope you undestand my bad english. :folded_hands:
        Tried without G…translation :face_savoring_food:
          @rantanplan in the upper right, (blue in image below) after you have selected the element u want to change
          type fo
          and u should get a list of ‘styles’ that start with fo and scroll down and select font-size
          then it with put the cursor after the :
          and type small
          and press enter
          you MAY have to add !important to override
          if this does what you want
          then use the mouse to select all in the upper right window
          right click and copy
          open the custom.css in some text editor
          and do , right click , paste
          in the middle pane (red in image below) , there is a item tree
          the right most corresponds to the item u selected
          use that in the css selector
          in calendar (right most column) that is td.time.light
          so the custom.css entry would be
          .modulename selector {
              styles
          or
          .calendar  td.time.light  {
               font-size: small;
            rantanplan
            OK, I think I’ve got it now.
            However, I have to connect a large monitor first, I use the official 7" monitor. Too small to work with it.:man_facepalming:
            Thank you for your help!
              @rantanplan you can do the debug from your pc, and still have the 7 in be fine
              in config.js
              set
              address:“0.0.0.0”,
              ipWhiltelist:[],
              then u can connect to MM from your desktop and debug…
              hit f5 to reload the pc MM page with the updated css…
              use the bitvise ssh client, you can edit the files on the pi from your pc… by double click like on the pc
              (enable ssh on the pi too)
