    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 19.8k Views 3 Watching
      sdetweil @Richard238
      @Richard238 said in Updating did nothing but gave fatal error warning.:
      .calendar .fas fa-fw fa-calendar-check-o {
      color: #00d255 /* 55=Green FF=Blue*/
      css selectors are the problem
      https://www.w3schools.com/cssref/css_selectors.asp
      so, your definition says
      for the CLASS calendar
      find ALL elements that match (.fas fa-fw fa-calendar-check)
      and set their color (foreground text color style ) to …
      so, lets examine the
      in the element this is ALL inside the class= attribute
      class="fas fa-fw fa-calendar-check"
      so to SELECT based on CLASS the names need dots in front
      name = tagname (<p, <img, <table …
      .name = class name ( .calendar
      #name = id of element ( id=“fred” #fred
      no space between selectors means ALL
      Selects all elements with both name1 and name2 set within its class attribute
      space between selectors means ALL AND directly child/parent
      Selects all elements with name2 that is a descendant of an element with name1
      and there are other types > < ~ … which mean this ??? in children elements, etc,
      what your string says is
      under the calendar CLASS (.calendar)
      for CLASS of fas (.fas)
      AND
      element of fa-fw (<fa-fw)
      AND
      element of fa-calendar-check (<fa-calendar-check)
      but you dont have the two ‘elements’ cause they are used in the class attribute
      in your case you only need ONE (not all)
      and its a CLASS (so leading .)
      .calendar .fa-calendar-check{
        Richard238
        Goodness, that’s complicated! Well, it kinda makes sense but, I’ll read it again when not so tired.
        Sadly, still nothing. (Commented second one out in case it was the cause, but no luck there.)
         .calendar .fa-calendar-check-o {
          color: #00d255 /* 55=Green FF=Blue */
        .calendar .fa-trash-o  {
          color: #C97F7F; /* Brown
        Also tried a known working fa icon from the weather module, but again, nothing.
          @Richard238 it worked with the change (oops)
          note that the selector is NOT -o
          I used your text in the message, not the ACTUAL class on the element… my bad…
          thats why we LOOK IT UP!..
            Richard238
            Even though the icon is fa-calendar-check-o
            https://fontawesome.com/v4/icon/calendar-check-o
            we omit the -o ?
              @Richard238 see the exact class used on the element, we use the ACTUAL info, not whatever ‘config’ says
              oh, using on MY machine, using the default calendar config …
                Richard238
                class? element? I try, but I’m not much of a coder. I’m hopelessly lost, as I’m sure you can tell.
                I appreciate your efforts but sadly this is way beyond my skills. :(
                I’ll live without the icon for now and perhaps revisit another day.
                  @Richard238 and I look at the fontawesome 6 lib and calendar-check-o is no more
                  I set calendar-check-o in my config and get nothing, look at the elements and see fa-calendar-check-o
                  but it doesn’t exist
                  https://fontawesome.com/icons
                    Richard238
                    Not coloured (even changing solid to light), but it’s an icon :)
                    .calendar .fa-solid fa-calendar {
                    .calendar .fa-light fa-trash-can  {
                      color: #C97F7F; /* Brown */
                    The other icons used to work, pre update.
                    Did MM change which fa library they use?
                    The fa libraries ought to be backwards compatible, no?
                    More tomorrow, I need sleep. :sleeping_face:
                      @Richard238 yes, libs should be backward compatible… but nobody cares much for that anymore…
                        Richard238
                        I now have coloured icons in the calendar:
                        Code now looks like this:
                        /* Calendar: config.js set to  symbol: 'fa-light fa-calendar', */
                        .calendar .fa-calendar-day {
                        /* Calendar: config.js set to  symbol: 'fa-light fa-trash-can', */
                        .calendar .fa-trash  {
                          color: #C97F7F /* Brown */
                          @Richard238 great job!
                            Richard238 @sdetweil
                            @sdetweil More by luck than skill, but thank you for your help and patience with this.
                            • 2 / 3
