Solved MMM-PythonPrint customisation
@sdetweil I have just had that lightbulb switch on in my head…
@RobCee i don’t think the image has python installed
@sdetweil you are correct. It doesn’t have python installed with it.
My next challenge is to work out how to get that up and running.Once I have it running I will get back to you on your module.
@RobCee short term while u are execed in, install python as usual
if you are using https://gitlab.com/khassel/magicmirror
he doesn’t provide a mechanism to add system components like python
@sdetweil that works, but the setup refreshes itself by default, so it wouldn’t last too long.
I will work it through. Thanks -
@RobCee while its challenging, its possible
I might open an issue of the docker image to allow a folder/file with additional packages to install at startup…
seems a waste to do it every refresh time tho
long ago and far away (2015) I had a product to install in an image, 1.5 GIG of product, and didn’t want to make a separate image for the different versions…
so I figured out how to install and capture that as a tarfile, and then
untar it as part of the startup…then the start script passed that as a parm to startup, so I could change the product on the fly, using the same tiny image…
@sdetweil it may just be quicker for me to learn how to do what my python code does in .js
It probably isn’t that complex. It is only reading stuff from web services and reporting it locally. I had hoped I could skip that stage, but I guess there are no short-cuts. -
@RobCee you can do most of the dev and test using a local file , outside of MM
xxx.js
then
node xxx.jsat least to get your main function working…
this code would work in the node helper
@sdetweil super. thanks for the pointer.
the docker image
karsten13/magicmirror:latest
doesn’t contain python. Simplest solution for this is to use the fat imagekarsten13/magicmirror:fat
, for more infos: https://khassel.gitlab.io/magicmirror/images/
