    MMM-PythonPrint customisation
    46 Posts 5 Posters 25.6k Views 5 Watching
      sdetweil @RobCee
      @RobCee ok, I also fixed the use of the pythonName and added it to the debug message
      [11.04.2022 11:04.20.218] [LOG]   PythonPrint spawning modules/MMM-PythonPrint/printit.py using python3
      [11.04.2022 11:04.25.244] [LOG]   PythonPrint sending program output=hello
        RobCee
        I’m not sure why, as I did manage to get it working at one point, but I think the issue is that I am using the MM OS Docker image to run all this.
        I think this means that the path expectations are different from the assumptions that I am making.
        I may have to give in and just build the whole thing manually - it will probably be quicker than trying to fault find the install, given it’s obfuscation.
          sdetweil @RobCee
          @RobCee yes, docker paths and if OUTSIDE the MM tree, then YOU have to add new volume statements to the docker setup to map them
            RobCee @sdetweil
            @sdetweil yeah, I am deliberately keeping all the module paths in the default place, but it still doesn’t like it.
            But if I go into the docker container, it doesn’t seem to have access to Python, so maybe that’s the problem.
            It is all rather confusing. (More so from your end, no doubt)
              sdetweil @RobCee
              @RobCee this.file(filename) will prepend the file system path to the module folder
              I just pushed a fix to do the same in the module, instead of the __dirname prefix
                RobCee @sdetweil
                @sdetweil But if I exec into a bash console in the docker container, it doesn’t seem to have access to Python, so maybe that’s the problem.
                  sdetweil @RobCee
                  @RobCee you had to install python in the container if it wasn’t as part of the instance
                    RobCee @sdetweil
                    @sdetweil I have just had that lightbulb switch on in my head…
                      sdetweil @RobCee
                      @RobCee i don’t think the image has python installed
                        RobCee @sdetweil
                        @sdetweil you are correct. It doesn’t have python installed with it.
                        My next challenge is to work out how to get that up and running.
                        Once I have it running I will get back to you on your module.
                          sdetweil @RobCee
                          @RobCee short term while u are execed in, install python as usual
                          if you are using https://gitlab.com/khassel/magicmirror
                          he doesn’t provide a mechanism to add system components like python
                          R karsten13K 2 Replies Last reply Reply Quote 0
                            RobCee @sdetweil
                            @sdetweil that works, but the setup refreshes itself by default, so it wouldn’t last too long.
                            I will work it through. Thanks
                              sdetweil @RobCee
                              @RobCee while its challenging, its possible
                              I might open an issue of the docker image to allow a folder/file with additional packages to install at startup…
                              seems a waste to do it every refresh time tho
                              long ago and far away (2015) I had a product to install in an image, 1.5 GIG of product, and didn’t want to make a separate image for the different versions…
                              so I figured out how to install and capture that as a tarfile, and then
                              untar it as part of the startup…
                              then the start script passed that as a parm to startup, so I could change the product on the fly, using the same tiny image…
                                RobCee @sdetweil
                                @sdetweil it may just be quicker for me to learn how to do what my python code does in .js
                                It probably isn’t that complex. It is only reading stuff from web services and reporting it locally. I had hoped I could skip that stage, but I guess there are no short-cuts.
                                  sdetweil @RobCee
                                  @RobCee you can do most of the dev and test using a local file , outside of MM
                                  xxx.js
                                  then
                                  node xxx.js
                                  at least to get your main function working…
                                  this code would work in the node helper
                                    RobCee @sdetweil
                                    @sdetweil super. thanks for the pointer.
                                    • karsten13K
                                      karsten13 @sdetweil
                                      the docker image karsten13/magicmirror:latest doesn’t contain python. Simplest solution for this is to use the fat image karsten13/magicmirror:fat, for more infos: https://khassel.gitlab.io/magicmirror/images/
                                        sdetweil @karsten13
                                        @karsten13 thanks… the doc needs help tho
                                        The difference between latest and fat is image size and installed
                                        those words are not used above that sentence, and so didn’t mean anything to me…
                                        I would propose adding in front of that sentence
                                        There are two images of each type created
                                        latest and fat
                                        docker pull image_name:latest
                                        or
                                        docker pull image_name:fat
                                        and then I would add a new line between these sentences
                                        debian packages. For most use cases the latest image is sufficient.
                                        Some modules need dependencies which are not includes in latest, e.g
                                        • karsten13K
                                          karsten13 @sdetweil
                                          yes, the docs … no native english speaker so docs are always a struggle. Thanks for the hints, will update …
                                            sdetweil @karsten13
                                            @karsten13 and I missed the latest/fat under the TAG column of your table… tldr(lol), my apologies
                                            • 2 / 3
