    MMM-PythonPrint customisation
    46 Posts 5 Posters 26.0k Views 5 Watching
      sdetweil @RobCee
      @RobCee you can do most of the dev and test using a local file , outside of MM
      xxx.js
      then
      node xxx.js
      at least to get your main function working…
      this code would work in the node helper
      R 1 Reply Last reply
        RobCee @sdetweil
        @sdetweil super. thanks for the pointer.
        • karsten13K
          karsten13 @sdetweil
          the docker image karsten13/magicmirror:latest doesn’t contain python. Simplest solution for this is to use the fat image karsten13/magicmirror:fat, for more infos: https://khassel.gitlab.io/magicmirror/images/
            sdetweil @karsten13
            @karsten13 thanks… the doc needs help tho
            The difference between latest and fat is image size and installed
            those words are not used above that sentence, and so didn’t mean anything to me…
            I would propose adding in front of that sentence
            There are two images of each type created
            latest and fat
            docker pull image_name:latest
            or
            docker pull image_name:fat
            and then I would add a new line between these sentences
            debian packages. For most use cases the latest image is sufficient.
            Some modules need dependencies which are not includes in latest, e.g
            karsten13K 1 Reply Last reply
            • karsten13K
              karsten13 @sdetweil
              yes, the docs … no native english speaker so docs are always a struggle. Thanks for the hints, will update …
                sdetweil @karsten13
                @karsten13 and I missed the latest/fat under the TAG column of your table… tldr(lol), my apologies
                  RobCee
                  @sdetweil I have started fresh and am still having the same issue.
                  New install of buster, fully updated.
                  Installed all the MM and node successfully.
                  MM runs as expected.
                  Checked that python and python3 are both available to the OS.
                  Added the MMM-PythonPrint to the modules dir.
                  [12.04.2022 11:22.45.613] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                  [12.04.2022 11:22.45.619] [ERROR] Whoops! There was an uncaught exception...
                  [12.04.2022 11:22.45.640] [ERROR] ReferenceError: _this is not defined
                      at Class.startit (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:27:24)
                      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:46:9)
                      at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
                      at Socket.emit (node:events:390:28)
                      at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                      at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39
                      at processTicksAndRejections (node:internal/process/task_queues:78:11)
                  This is my config section:
                  			module:"MMM-PythonPrint",
                  			position:"center",
                  			disabled:false,
                  				// name of the python process to execute (could be python3)
                  				pythonName: 'python',
                  				// command file in module folder
                  				// if false, YOU will provide the full path to the python program
                  				localfolder: true,
                  				// spawn a python pgm that writes over and over (timed maybe), but keeps running
                  				command: 'printit.py',
                  				repetative: true,
                  				// spawn a one time output  script, but relaunch it every cycletime milliseconds
                  				// repretative: false,
                  				// command: 'printitonce.py',
                  				cycletime: 2000,
                  				// print debugging messages from the node_helper
                  				debug: true
                    sdetweil @RobCee
                    @RobCee weird, sorry, typo… fixed
                    git pull to get the update
                      RobCee @sdetweil
                      @sdetweil I found another, just up from that one - you have a missing ‘t’ in this line
                      this.config.command=this.config.command.slice(his.config.pythonName.length)
                        sdetweil @RobCee
                        @RobCee fixed… bad day at the finger farm…yikes sorry
                          RobCee
                          But even with that _ removed, I am still getting an odd error:
                           TypeError: this.file is not a function
                            sdetweil @RobCee
                            @RobCee ok, fixed, tested… sorry again
                            git pull
                              RobCee @sdetweil
                              @sdetweil - apologies not necessary - I am just happy you are able to look at it.
                              Hurrah! It works!
                                diemen112
                                i have also the MM os and i try to make it work
                                I have added - /usr/bin/python3:/usr/bin/python3 to the docker compose
                                and now i have the error
                                [15.07.2022 14:23.42.599] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                                [15.07.2022 14:23.42.602] [LOG]   PythonPrint spawning /opt/magic_mirror/modules/MMM-PythonPrint/print_test.py using python3
                                [15.07.2022 14:23.42.686] [LOG]   PythonPrint program error=Could not find platform independent libraries <prefix>
                                Could not find platform dependent libraries <exec_prefix>
                                Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
                                Fatal Python error: initfsencoding: unable to load the file system codec
                                ModuleNotFoundError: No module named 'encodings'
                                Current thread 0x76fb37a0 (most recent call first):
                                a played around with adding $PYTHONHOME to env but without any result
                                does anyone know a work around to find the libraries?
                                S karsten13K 2 Replies Last reply
                                  sdetweil @diemen112
                                  @diemen112 I think this answers
                                  https://askubuntu.com/questions/905372/could-not-find-platform-independent-libraries-prefix
                                  running under docker is a fun experience?
                                  did u install python as part of the container startup?
                                  • karsten13K
                                    karsten13 @diemen112
                                    @diemen112 said in MMM-PythonPrint customisation:
                                    this will not work. You have to use the fat image, see my post above (Apr 11)
                                      diemen112
                                      Thank you for the help,
                                      I made it work with adding some python dependent directory’s to the docker-compose file
                                      • kayakbabeK
                                        kayakbabe
                                        Sam,
                                        Thank you for this MMM-PythonPrint. More than the sample module this really helped me follow how to wrap my head around how the script.js node_helper and anything else work together. The way you worded the variables and the input and output text really made sense and made it easy to follow what is happening. I am learning a lot. Again, Thank you.
                                        Kelly
                                          sdetweil @kayakbabe
                                          @kayakbabe awesome, glad it helped!
                                          kayakbabeK 1 Reply Last reply
                                          • kayakbabeK
                                            kayakbabe @sdetweil
                                            @sdetweil I’m looking at the configuration variable repetative and trying to figure out what it is for.
                                            is this correct logic for true and false?
                                            repetative: true
                                            if your python script runs in a loop forever by itself so the spawn in node helper will just keep its connection to the python script open
                                            repetative: false
                                            if your python script runs one time, and you need node_helper to keep spawning over and over so you can get the info from the python script over and over
                                            • 2 / 3
