    MMM-PythonPrint customisation
    46 Posts 5 Posters 25.6k Views 5 Watching
      sdetweil @RobCee
      @RobCee short term while u are execed in, install python as usual
      if you are using https://gitlab.com/khassel/magicmirror
      he doesn’t provide a mechanism to add system components like python
      R karsten13K 2 Replies Last reply Reply Quote 0
        RobCee @sdetweil
        @sdetweil that works, but the setup refreshes itself by default, so it wouldn’t last too long.
        I will work it through. Thanks
          sdetweil @RobCee
          @RobCee while its challenging, its possible
          I might open an issue of the docker image to allow a folder/file with additional packages to install at startup…
          seems a waste to do it every refresh time tho
          long ago and far away (2015) I had a product to install in an image, 1.5 GIG of product, and didn’t want to make a separate image for the different versions…
          so I figured out how to install and capture that as a tarfile, and then
          untar it as part of the startup…
          then the start script passed that as a parm to startup, so I could change the product on the fly, using the same tiny image…
            RobCee @sdetweil
            @sdetweil it may just be quicker for me to learn how to do what my python code does in .js
            It probably isn’t that complex. It is only reading stuff from web services and reporting it locally. I had hoped I could skip that stage, but I guess there are no short-cuts.
              sdetweil @RobCee
              @RobCee you can do most of the dev and test using a local file , outside of MM
              xxx.js
              then
              node xxx.js
              at least to get your main function working…
              this code would work in the node helper
                RobCee @sdetweil
                @sdetweil super. thanks for the pointer.
                • karsten13K
                  karsten13 @sdetweil
                  the docker image karsten13/magicmirror:latest doesn’t contain python. Simplest solution for this is to use the fat image karsten13/magicmirror:fat, for more infos: https://khassel.gitlab.io/magicmirror/images/
                    sdetweil @karsten13
                    @karsten13 thanks… the doc needs help tho
                    The difference between latest and fat is image size and installed
                    those words are not used above that sentence, and so didn’t mean anything to me…
                    I would propose adding in front of that sentence
                    There are two images of each type created
                    latest and fat
                    docker pull image_name:latest
                    or
                    docker pull image_name:fat
                    and then I would add a new line between these sentences
                    debian packages. For most use cases the latest image is sufficient.
                    Some modules need dependencies which are not includes in latest, e.g
                    • karsten13K
                      karsten13 @sdetweil
                      yes, the docs … no native english speaker so docs are always a struggle. Thanks for the hints, will update …
                        sdetweil @karsten13
                        @karsten13 and I missed the latest/fat under the TAG column of your table… tldr(lol), my apologies
                          RobCee
                          @sdetweil I have started fresh and am still having the same issue.
                          New install of buster, fully updated.
                          Installed all the MM and node successfully.
                          MM runs as expected.
                          Checked that python and python3 are both available to the OS.
                          Added the MMM-PythonPrint to the modules dir.
                          [12.04.2022 11:22.45.613] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                          [12.04.2022 11:22.45.619] [ERROR] Whoops! There was an uncaught exception...
                          [12.04.2022 11:22.45.640] [ERROR] ReferenceError: _this is not defined
                              at Class.startit (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:27:24)
                              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:46:9)
                              at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
                              at Socket.emit (node:events:390:28)
                              at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                              at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39
                              at processTicksAndRejections (node:internal/process/task_queues:78:11)
                          This is my config section:
                          			module:"MMM-PythonPrint",
                          			position:"center",
                          			disabled:false,
                          				// name of the python process to execute (could be python3)
                          				pythonName: 'python',
                          				// command file in module folder
                          				// if false, YOU will provide the full path to the python program
                          				localfolder: true,
                          				// spawn a python pgm that writes over and over (timed maybe), but keeps running
                          				command: 'printit.py',
                          				repetative: true,
                          				// spawn a one time output  script, but relaunch it every cycletime milliseconds
                          				// repretative: false,
                          				// command: 'printitonce.py',
                          				cycletime: 2000,
                          				// print debugging messages from the node_helper
                          				debug: true
                            sdetweil @RobCee
                            @RobCee weird, sorry, typo… fixed
                            git pull to get the update
                              RobCee @sdetweil
                              @sdetweil I found another, just up from that one - you have a missing ‘t’ in this line
                              this.config.command=this.config.command.slice(his.config.pythonName.length)
                                sdetweil @RobCee
                                @RobCee fixed… bad day at the finger farm…yikes sorry
                                  RobCee
                                  But even with that _ removed, I am still getting an odd error:
                                   TypeError: this.file is not a function
                                    sdetweil @RobCee
                                    @RobCee ok, fixed, tested… sorry again
                                    git pull
                                      RobCee @sdetweil
                                      @sdetweil - apologies not necessary - I am just happy you are able to look at it.
                                      Hurrah! It works!
                                        diemen112
                                        i have also the MM os and i try to make it work
                                        I have added - /usr/bin/python3:/usr/bin/python3 to the docker compose
                                        and now i have the error
                                        [15.07.2022 14:23.42.599] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                                        [15.07.2022 14:23.42.602] [LOG]   PythonPrint spawning /opt/magic_mirror/modules/MMM-PythonPrint/print_test.py using python3
                                        [15.07.2022 14:23.42.686] [LOG]   PythonPrint program error=Could not find platform independent libraries <prefix>
                                        Could not find platform dependent libraries <exec_prefix>
                                        Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
                                        Fatal Python error: initfsencoding: unable to load the file system codec
                                        ModuleNotFoundError: No module named 'encodings'
                                        Current thread 0x76fb37a0 (most recent call first):
                                        a played around with adding $PYTHONHOME to env but without any result
                                        does anyone know a work around to find the libraries?
                                        S karsten13K 2 Replies Last reply Reply Quote 0
                                          sdetweil @diemen112
                                          @diemen112 I think this answers
                                          https://askubuntu.com/questions/905372/could-not-find-platform-independent-libraries-prefix
                                          running under docker is a fun experience?
                                          did u install python as part of the container startup?
                                          • karsten13K
                                            karsten13 @diemen112
                                            @diemen112 said in MMM-PythonPrint customisation:
                                            this will not work. You have to use the fat image, see my post above (Apr 11)
                                            • 2 / 3
