    MMM-PythonPrint customisation
    46 Posts 5 Posters 26.0k Views 5 Watching
      RobCee @sdetweil
      @sdetweil that works, but the setup refreshes itself by default, so it wouldn’t last too long.
      I will work it through. Thanks
        sdetweil @RobCee
        @RobCee while its challenging, its possible
        I might open an issue of the docker image to allow a folder/file with additional packages to install at startup…
        seems a waste to do it every refresh time tho
        long ago and far away (2015) I had a product to install in an image, 1.5 GIG of product, and didn’t want to make a separate image for the different versions…
        so I figured out how to install and capture that as a tarfile, and then
        untar it as part of the startup…
        then the start script passed that as a parm to startup, so I could change the product on the fly, using the same tiny image…
        R 1 Reply Last reply
          RobCee @sdetweil
          @sdetweil it may just be quicker for me to learn how to do what my python code does in .js
          It probably isn’t that complex. It is only reading stuff from web services and reporting it locally. I had hoped I could skip that stage, but I guess there are no short-cuts.
            sdetweil @RobCee
            @RobCee you can do most of the dev and test using a local file , outside of MM
            xxx.js
            then
            node xxx.js
            at least to get your main function working…
            this code would work in the node helper
              RobCee @sdetweil
              @sdetweil super. thanks for the pointer.
              • karsten13K
                karsten13 @sdetweil
                the docker image karsten13/magicmirror:latest doesn’t contain python. Simplest solution for this is to use the fat image karsten13/magicmirror:fat, for more infos: https://khassel.gitlab.io/magicmirror/images/
                  sdetweil @karsten13
                  @karsten13 thanks… the doc needs help tho
                  The difference between latest and fat is image size and installed
                  those words are not used above that sentence, and so didn’t mean anything to me…
                  I would propose adding in front of that sentence
                  There are two images of each type created
                  latest and fat
                  docker pull image_name:latest
                  or
                  docker pull image_name:fat
                  and then I would add a new line between these sentences
                  debian packages. For most use cases the latest image is sufficient.
                  Some modules need dependencies which are not includes in latest, e.g
                  karsten13K 1 Reply Last reply
                  • karsten13K
                    karsten13 @sdetweil
                    yes, the docs … no native english speaker so docs are always a struggle. Thanks for the hints, will update …
                      sdetweil @karsten13
                      @karsten13 and I missed the latest/fat under the TAG column of your table… tldr(lol), my apologies
                        RobCee
                        @sdetweil I have started fresh and am still having the same issue.
                        New install of buster, fully updated.
                        Installed all the MM and node successfully.
                        MM runs as expected.
                        Checked that python and python3 are both available to the OS.
                        Added the MMM-PythonPrint to the modules dir.
                        [12.04.2022 11:22.45.613] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                        [12.04.2022 11:22.45.619] [ERROR] Whoops! There was an uncaught exception...
                        [12.04.2022 11:22.45.640] [ERROR] ReferenceError: _this is not defined
                            at Class.startit (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:27:24)
                            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:46:9)
                            at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
                            at Socket.emit (node:events:390:28)
                            at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                            at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39
                            at processTicksAndRejections (node:internal/process/task_queues:78:11)
                        This is my config section:
                        			module:"MMM-PythonPrint",
                        			position:"center",
                        			disabled:false,
                        				// name of the python process to execute (could be python3)
                        				pythonName: 'python',
                        				// command file in module folder
                        				// if false, YOU will provide the full path to the python program
                        				localfolder: true,
                        				// spawn a python pgm that writes over and over (timed maybe), but keeps running
                        				command: 'printit.py',
                        				repetative: true,
                        				// spawn a one time output  script, but relaunch it every cycletime milliseconds
                        				// repretative: false,
                        				// command: 'printitonce.py',
                        				cycletime: 2000,
                        				// print debugging messages from the node_helper
                        				debug: true
                          sdetweil @RobCee
                          @RobCee weird, sorry, typo… fixed
                          git pull to get the update
                            RobCee @sdetweil
                            @sdetweil I found another, just up from that one - you have a missing ‘t’ in this line
                            this.config.command=this.config.command.slice(his.config.pythonName.length)
                              sdetweil @RobCee
                              @RobCee fixed… bad day at the finger farm…yikes sorry
                                RobCee
                                But even with that _ removed, I am still getting an odd error:
                                 TypeError: this.file is not a function
                                  sdetweil @RobCee
                                  @RobCee ok, fixed, tested… sorry again
                                  git pull
                                    RobCee @sdetweil
                                    @sdetweil - apologies not necessary - I am just happy you are able to look at it.
                                    Hurrah! It works!
                                      diemen112
                                      i have also the MM os and i try to make it work
                                      I have added - /usr/bin/python3:/usr/bin/python3 to the docker compose
                                      and now i have the error
                                      [15.07.2022 14:23.42.599] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                                      [15.07.2022 14:23.42.602] [LOG]   PythonPrint spawning /opt/magic_mirror/modules/MMM-PythonPrint/print_test.py using python3
                                      [15.07.2022 14:23.42.686] [LOG]   PythonPrint program error=Could not find platform independent libraries <prefix>
                                      Could not find platform dependent libraries <exec_prefix>
                                      Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
                                      Fatal Python error: initfsencoding: unable to load the file system codec
                                      ModuleNotFoundError: No module named 'encodings'
                                      Current thread 0x76fb37a0 (most recent call first):
                                      a played around with adding $PYTHONHOME to env but without any result
                                      does anyone know a work around to find the libraries?
                                      S karsten13K 2 Replies Last reply
                                        sdetweil @diemen112
                                        @diemen112 I think this answers
                                        https://askubuntu.com/questions/905372/could-not-find-platform-independent-libraries-prefix
                                        running under docker is a fun experience?
                                        did u install python as part of the container startup?
                                        • karsten13K
                                          karsten13 @diemen112
                                          @diemen112 said in MMM-PythonPrint customisation:
                                          this will not work. You have to use the fat image, see my post above (Apr 11)
                                            diemen112
                                            Thank you for the help,
                                            I made it work with adding some python dependent directory’s to the docker-compose file
                                            • 2 / 3
