    MMM-PythonPrint customisation
    46 Posts 5 Posters 25.6k Views 5 Watching
    • karsten13K
      karsten13 @sdetweil
      the docker image karsten13/magicmirror:latest doesn’t contain python. Simplest solution for this is to use the fat image karsten13/magicmirror:fat, for more infos: https://khassel.gitlab.io/magicmirror/images/
        sdetweil @karsten13
        @karsten13 thanks… the doc needs help tho
        The difference between latest and fat is image size and installed
        those words are not used above that sentence, and so didn’t mean anything to me…
        I would propose adding in front of that sentence
        There are two images of each type created
        latest and fat
        docker pull image_name:latest
        or
        docker pull image_name:fat
        and then I would add a new line between these sentences
        debian packages. For most use cases the latest image is sufficient.
        Some modules need dependencies which are not includes in latest, e.g
        • karsten13K
          karsten13 @sdetweil
          yes, the docs … no native english speaker so docs are always a struggle. Thanks for the hints, will update …
            sdetweil @karsten13
            @karsten13 and I missed the latest/fat under the TAG column of your table… tldr(lol), my apologies
              RobCee
              @sdetweil I have started fresh and am still having the same issue.
              New install of buster, fully updated.
              Installed all the MM and node successfully.
              MM runs as expected.
              Checked that python and python3 are both available to the OS.
              Added the MMM-PythonPrint to the modules dir.
              [12.04.2022 11:22.45.613] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
              [12.04.2022 11:22.45.619] [ERROR] Whoops! There was an uncaught exception...
              [12.04.2022 11:22.45.640] [ERROR] ReferenceError: _this is not defined
                  at Class.startit (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:27:24)
                  at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:46:9)
                  at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
                  at Socket.emit (node:events:390:28)
                  at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                  at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39
                  at processTicksAndRejections (node:internal/process/task_queues:78:11)
              This is my config section:
              			module:"MMM-PythonPrint",
              			position:"center",
              			disabled:false,
              				// name of the python process to execute (could be python3)
              				pythonName: 'python',
              				// command file in module folder
              				// if false, YOU will provide the full path to the python program
              				localfolder: true,
              				// spawn a python pgm that writes over and over (timed maybe), but keeps running
              				command: 'printit.py',
              				repetative: true,
              				// spawn a one time output  script, but relaunch it every cycletime milliseconds
              				// repretative: false,
              				// command: 'printitonce.py',
              				cycletime: 2000,
              				// print debugging messages from the node_helper
              				debug: true
                sdetweil @RobCee
                @RobCee weird, sorry, typo… fixed
                git pull to get the update
                  RobCee @sdetweil
                  @sdetweil I found another, just up from that one - you have a missing ‘t’ in this line
                  this.config.command=this.config.command.slice(his.config.pythonName.length)
                    sdetweil @RobCee
                    @RobCee fixed… bad day at the finger farm…yikes sorry
                      RobCee
                      But even with that _ removed, I am still getting an odd error:
                       TypeError: this.file is not a function
                        sdetweil @RobCee
                        @RobCee ok, fixed, tested… sorry again
                        git pull
                          RobCee @sdetweil
                          @sdetweil - apologies not necessary - I am just happy you are able to look at it.
                          Hurrah! It works!
                            diemen112
                            i have also the MM os and i try to make it work
                            I have added - /usr/bin/python3:/usr/bin/python3 to the docker compose
                            and now i have the error
                            [15.07.2022 14:23.42.599] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                            [15.07.2022 14:23.42.602] [LOG]   PythonPrint spawning /opt/magic_mirror/modules/MMM-PythonPrint/print_test.py using python3
                            [15.07.2022 14:23.42.686] [LOG]   PythonPrint program error=Could not find platform independent libraries <prefix>
                            Could not find platform dependent libraries <exec_prefix>
                            Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
                            Fatal Python error: initfsencoding: unable to load the file system codec
                            ModuleNotFoundError: No module named 'encodings'
                            Current thread 0x76fb37a0 (most recent call first):
                            a played around with adding $PYTHONHOME to env but without any result
                            does anyone know a work around to find the libraries?
                            S karsten13K 2 Replies Last reply Reply Quote 0
                              sdetweil @diemen112
                              @diemen112 I think this answers
                              https://askubuntu.com/questions/905372/could-not-find-platform-independent-libraries-prefix
                              running under docker is a fun experience?
                              did u install python as part of the container startup?
                              • karsten13K
                                karsten13 @diemen112
                                @diemen112 said in MMM-PythonPrint customisation:
                                this will not work. You have to use the fat image, see my post above (Apr 11)
                                  diemen112
                                  Thank you for the help,
                                  I made it work with adding some python dependent directory’s to the docker-compose file
                                  • kayakbabeK
                                    kayakbabe
                                    Sam,
                                    Thank you for this MMM-PythonPrint. More than the sample module this really helped me follow how to wrap my head around how the script.js node_helper and anything else work together. The way you worded the variables and the input and output text really made sense and made it easy to follow what is happening. I am learning a lot. Again, Thank you.
                                    Kelly
                                      sdetweil @kayakbabe
                                      @kayakbabe awesome, glad it helped!
                                      kayakbabeK 1 Reply Last reply Reply Quote 0
                                      • kayakbabeK
                                        kayakbabe @sdetweil
                                        @sdetweil I’m looking at the configuration variable repetative and trying to figure out what it is for.
                                        is this correct logic for true and false?
                                        repetative: true
                                        if your python script runs in a loop forever by itself so the spawn in node helper will just keep its connection to the python script open
                                        repetative: false
                                        if your python script runs one time, and you need node_helper to keep spawning over and over so you can get the info from the python script over and over
                                          sdetweil @kayakbabe
                                          @kayakbabe so , maybe your python script starts and runs, prints one line, and ends. current temp is x
                                          is that all you want your module to present, one line?
                                          or do you want the output every few seconds minutes
                                          this is repetative:false, but my module will rerun the script every cycle time milliseconds
                                          but some python scripts do that internally.
                                          print, sleep, print, sleep, print, sleep, print…
                                          this is repetative: true
                                          my module will just start the python script
                                          there are two different ways to capture the output
                                          should have named parm
                                          script_is_long_running
                                          I provided a sample of each
                                          also, in many cases, you are using someone else’s script and don’t have control over how it works, and don’t want to rewrite it
                                          • 2 / 3
