    MMM-PythonPrint customisation
    46 Posts 5 Posters 26.0k Views 5 Watching
      sdetweil @RobCee
      @RobCee while its challenging, its possible
      I might open an issue of the docker image to allow a folder/file with additional packages to install at startup…
      seems a waste to do it every refresh time tho
      long ago and far away (2015) I had a product to install in an image, 1.5 GIG of product, and didn’t want to make a separate image for the different versions…
      so I figured out how to install and capture that as a tarfile, and then
      untar it as part of the startup…
      then the start script passed that as a parm to startup, so I could change the product on the fly, using the same tiny image…
      R 1 Reply Last reply
        RobCee @sdetweil
        @sdetweil it may just be quicker for me to learn how to do what my python code does in .js
        It probably isn’t that complex. It is only reading stuff from web services and reporting it locally. I had hoped I could skip that stage, but I guess there are no short-cuts.
          sdetweil @RobCee
          @RobCee you can do most of the dev and test using a local file , outside of MM
          xxx.js
          then
          node xxx.js
          at least to get your main function working…
          this code would work in the node helper
            RobCee @sdetweil
            @sdetweil super. thanks for the pointer.
            • karsten13K
              karsten13 @sdetweil
              the docker image karsten13/magicmirror:latest doesn’t contain python. Simplest solution for this is to use the fat image karsten13/magicmirror:fat, for more infos: https://khassel.gitlab.io/magicmirror/images/
                sdetweil @karsten13
                @karsten13 thanks… the doc needs help tho
                The difference between latest and fat is image size and installed
                those words are not used above that sentence, and so didn’t mean anything to me…
                I would propose adding in front of that sentence
                There are two images of each type created
                latest and fat
                docker pull image_name:latest
                or
                docker pull image_name:fat
                and then I would add a new line between these sentences
                debian packages. For most use cases the latest image is sufficient.
                Some modules need dependencies which are not includes in latest, e.g
                karsten13K 1 Reply Last reply
                • karsten13K
                  karsten13 @sdetweil
                  yes, the docs … no native english speaker so docs are always a struggle. Thanks for the hints, will update …
                    sdetweil @karsten13
                    @karsten13 and I missed the latest/fat under the TAG column of your table… tldr(lol), my apologies
                      RobCee
                      @sdetweil I have started fresh and am still having the same issue.
                      New install of buster, fully updated.
                      Installed all the MM and node successfully.
                      MM runs as expected.
                      Checked that python and python3 are both available to the OS.
                      Added the MMM-PythonPrint to the modules dir.
                      [12.04.2022 11:22.45.613] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                      [12.04.2022 11:22.45.619] [ERROR] Whoops! There was an uncaught exception...
                      [12.04.2022 11:22.45.640] [ERROR] ReferenceError: _this is not defined
                          at Class.startit (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:27:24)
                          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-PythonPrint/node_helper.js:46:9)
                          at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
                          at Socket.emit (node:events:390:28)
                          at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                          at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39
                          at processTicksAndRejections (node:internal/process/task_queues:78:11)
                      This is my config section:
                      			module:"MMM-PythonPrint",
                      			position:"center",
                      			disabled:false,
                      				// name of the python process to execute (could be python3)
                      				pythonName: 'python',
                      				// command file in module folder
                      				// if false, YOU will provide the full path to the python program
                      				localfolder: true,
                      				// spawn a python pgm that writes over and over (timed maybe), but keeps running
                      				command: 'printit.py',
                      				repetative: true,
                      				// spawn a one time output  script, but relaunch it every cycletime milliseconds
                      				// repretative: false,
                      				// command: 'printitonce.py',
                      				cycletime: 2000,
                      				// print debugging messages from the node_helper
                      				debug: true
                        sdetweil @RobCee
                        @RobCee weird, sorry, typo… fixed
                        git pull to get the update
                          RobCee @sdetweil
                          @sdetweil I found another, just up from that one - you have a missing ‘t’ in this line
                          this.config.command=this.config.command.slice(his.config.pythonName.length)
                            sdetweil @RobCee
                            @RobCee fixed… bad day at the finger farm…yikes sorry
                              RobCee
                              But even with that _ removed, I am still getting an odd error:
                               TypeError: this.file is not a function
                                sdetweil @RobCee
                                @RobCee ok, fixed, tested… sorry again
                                git pull
                                  RobCee @sdetweil
                                  @sdetweil - apologies not necessary - I am just happy you are able to look at it.
                                  Hurrah! It works!
                                    diemen112
                                    i have also the MM os and i try to make it work
                                    I have added - /usr/bin/python3:/usr/bin/python3 to the docker compose
                                    and now i have the error
                                    [15.07.2022 14:23.42.599] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
                                    [15.07.2022 14:23.42.602] [LOG]   PythonPrint spawning /opt/magic_mirror/modules/MMM-PythonPrint/print_test.py using python3
                                    [15.07.2022 14:23.42.686] [LOG]   PythonPrint program error=Could not find platform independent libraries <prefix>
                                    Could not find platform dependent libraries <exec_prefix>
                                    Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
                                    Fatal Python error: initfsencoding: unable to load the file system codec
                                    ModuleNotFoundError: No module named 'encodings'
                                    Current thread 0x76fb37a0 (most recent call first):
                                    a played around with adding $PYTHONHOME to env but without any result
                                    does anyone know a work around to find the libraries?
                                    S karsten13K 2 Replies Last reply
                                      sdetweil @diemen112
                                      @diemen112 I think this answers
                                      https://askubuntu.com/questions/905372/could-not-find-platform-independent-libraries-prefix
                                      running under docker is a fun experience?
                                      did u install python as part of the container startup?
                                      • karsten13K
                                        karsten13 @diemen112
                                        @diemen112 said in MMM-PythonPrint customisation:
                                        this will not work. You have to use the fat image, see my post above (Apr 11)
                                          diemen112
                                          Thank you for the help,
                                          I made it work with adding some python dependent directory’s to the docker-compose file
                                          • kayakbabeK
                                            kayakbabe
                                            Sam,
                                            Thank you for this MMM-PythonPrint. More than the sample module this really helped me follow how to wrap my head around how the script.js node_helper and anything else work together. The way you worded the variables and the input and output text really made sense and made it easy to follow what is happening. I am learning a lot. Again, Thank you.
                                            Kelly
                                            • 2 / 3
