    Error when updating and reinstalling 2.19.0
    8 Posts 2 Posters 1.9k Views 2 Watching
      det
      Use this script:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      and get this error message
      Cloning MagicMirror Done!
      Installing dependencies ...
      npm ERR! code ETARGET
      npm ERR! notarget No matching version found for mime-db@1.52.0.
      npm ERR! notarget In most cases you or one of your dependencies are requesting
      npm ERR! notarget a package version that doesn't exist.
      npm ERR!     /home/pi/.npm/_logs/2022-04-17T08_19_53_669Z-debug-0.log
      Unable to install dependencies!
      what can i do?
      Thanks for your help
        sdetweil @det
        @det can u send me the ~/install.log
        my same userid at Gmail.
          det
          I have sent the logs.
            sdetweil @det
            @det I replied
              det
              I have completely rebuilt the MM2 and set up all modules again.
              Now the 2.19.0 is running.
                sdetweil @det
                @det can u say what you did differently?
                  det
                  I have reinstalled bullseye on another ssd card and set it up.
                  Updated with:
                  sudo apt-get update
                  sudo apt-get upgrade
                  Now:
                  curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
                  sudo apt install -y nodejs
                  Then run the install script:
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                  loaded all modules from git and executed npm install if necessary.
                  (only with MMM-Navigate there were problems, I copied this from the old ssd-card)
                  Now I copied the config.js and css, that’s it.
                  With kind regards and Thanks
                    sdetweil @det
                    @det just for your info.
                    my install script does all the things u did manually…
                    apt update/upgrade and install node/npm.
