    Three module issues from a new user
    27 Posts 6 Posters 11.6k Views 6 Watching
      sdetweil @vilhelmr
      @vilhelmr weather takes sunrise/set from the location you configured for weather…
      clock in utc+1, weather location in Austin TX
      for example
        sdetweil @vilhelmr
        @vilhelmr for icons I would look in the developers window, ctrl-shift-i, console tab, for any errors.
        filter on calendar, by putting unique part of module name in filter field (cal for example)
        • V Offline
          vildhjelm @sdetweil
          I managed to get unique icons for each calendar, through trial and error with font awesome. Not all “free” fonts are supported, I think “brands” aren’t.
          Do you know, if I can set icons that I’ve stored locally? There are a lot on the noun project that would be excellent :).
            sdetweil @vildhjelm
            @vildhjelm said in Three module issues from a new user:
            i do not know myself, but I would think you could
            <img icon="68" src="/img/emoji/U263a.ico" alt=":-)" />
            the base for MM web server is MagicMirror, so
            src="/modules/{modulename}/{sub_folder}/{filename}"
            replace {} with the appropriate name, if any
              sdetweil @vildhjelm
              @vildhjelm where u able to get this working?
                skyfall
                Hi all, was working on the same thing.
                Some icons I wanted to use are in brands, and can’t figure out how to invoke it properly. Tried adding imports in fontawesome.css for it, but no go. Anyone know how/why brands wont work? They are considered free use.
                  sdetweil @skyfall
                  @skyfall I do not KNOW for sure… maybe they have to be downloaded separately?
                  see the last few posts here on getting separate fonts usable after download
                  https://forum.magicmirror.builders/topic/8758/change-fonts/6?_=1650986841007
                    skyfall @sdetweil
                    @sdetweil I don’t think so, I’ve been looking into it and it is included in all.min.css; that’s where the other ones get imported from. Maybe we’re not invoking it properly since the FA 4->6 upgrade that happened in January?
                      sdetweil @skyfall
                      @skyfall
                      maybe all you have to do is npm install the right stuff in the vendor folder
                      "dependencies": {
                      	"@fortawesome/fontawesome-free": "^6.1.1",
                      and this is in the vendor/css/font-awesome.css
                      @import url(“…/node_modules/@fortawesome/fontawesome-free/css/all.min.css”);
                      @import url("…/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.
                      these files are in the folder
                      sam@sams:~/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free/css$ ls
                      all.css fontawesome.min.css svg-with-js.css v4-shims.min.css
                      all.min.css regular.css svg-with-js.min.css v5-font-face.css
                      brands.css regular.min.css v4-font-face.css v5-font-face.min.css
                      brands.min.css solid.css v4-font-face.min.css
                      fontawesome.css solid.min.css v4-shims.css
                      i looked up one of the items listed in brands, .fa-apple-pay
                      in all.css… and its there
                        skyfall @sdetweil
                        @sdetweil I think we’re on to something here. I’m embarassed but I did notice my dependencies were out of date. I was running FA 5.13.3. Reinstalled and reverified and now running 6.1.1. However, when invoking ‘canadian-maple-leaf’ for example, it’s now showing a broken icon symbol versus nothing!
                        I did also notice it isn’t loading the .woff2 file for the brands fonts, even though it is in the correct directory.
                          skyfall @skyfall
                          I’ve figured it out!
                          Like the original post, I’m working with Calendar module. I wanted to understand why we could write, say symbol: “cloud” instead of having to declare the full “fas fa-fw fa-cloud” to invoke the symbol.
                          I went into /modules/default/calendar/calendar.js and noticed the following section of code:
                          const symbols = this.symbolsForEvent(event);
                                                          symbols.forEach((s, index) => {
        const symbol = document.createElement("span");
        symbol.className = "fas fa-fw fa-" + s;
        if (index > 0) {
        symbol.style.paddingLeft = "5px";
        symbolWrapper.appendChild(symbol);
                                                          eventWrapper.appendChild(symbolWrapper);
                                                  } else if (this.config.timeFormat === "dateheaders") {
                                                          const blankCell = document.createElement("td");
                                                          blankCell.innerHTML = "&nbsp;&nbsp;&nbsp;";
                                                          eventWrapper.appendChild(blankCell);
                          calendar.js is hardcoding the fas (solid) font family in, not allowing us to invoke a family like fab (brands). setting the line:
                          to just:
                          symbol.className = s;
                          forces us to redeclare every symbol in config.js from “cloud” to “fas fa-fw fa-cloud”, but we can now access all available FA icons.
                          And so, I get my leaf :)
                          6f18f2a7-0b58-4f38-bcf8-994695134f0c-Screen Shot 2022-04-28 at 17.37.44.png Screen Shot 2022-04-28 at 17.37.44
                          S 2 Replies Last reply Reply Quote 1
                            sdetweil @skyfall
                            @skyfall awesome
                              sdetweil @skyfall
                              @skyfall I think we could fix that with a little smarter code, and not break existing modules
                              change
                              to
                              // if requested symbol name starts with 'fa-' , get the substring after 'fa-'
                              // if  not, use as is
                              symbol.className = "fas fa-fw fa-" +(s.startsWith('fa-')?s.slice(3):s);
                              of course if the other icon names start with fa-, then u didn’t need any of this…
                              can u provide an example of the branded icon name?
                                skyfall
                                I was using https://fontawesome.com/icons/canadian-maple-leaf?s=brands for example
                                I was thinking about how to fix this without breaking too; could just be an else if statement checking to see if it starts with “fab” or “fal”, otherwise keeping the fas hardcode. Would let us declare other families and keep the shorthand for the default fas configuration.
                                S luisestradaL 2 Replies Last reply Reply Quote 0
                                  sdetweil @skyfall
                                  @skyfall oh, I see you have to call out fa-brands
                                  hm…
                                  maybe if the specific string has more than 1 word
                                  like “fa-brands fa-iconname”
                                  then you use as is (full string)
                                  otherwise you use the default approach of appending the name to the ‘fa-’ already there
                                  // if there is a space in the name, 'collectionname iconname' use the string as is
                                  // for example "fa-brands fa-canadian-maple-leaf"
                                  // else use the current approach
                                  symbol.className =(s.indexOf(' ')>0?s:( "fas fa-fw fa-" +s));
                                  this would let other prefix specific icons in, and not break old…
                                  luisestradaL 1 Reply Last reply Reply Quote 0
                                    skyfall
                                    Yeah, there’s a few things to try and we can make it work without breaking default notation
                                    I think one thing to keep in mind is MM seems to refer to them as “fab” instead of fa-brands; not sure where that translation happens.
                                    I did see some of the commits from January that initially addresses this. I’m mobile right now so I don’t have the references, but it looked like this convention is used in more places than just calendar. Should be the same fix for all instances though.
                                    I’ll experiment with it a bit too when I sit down to look.
                                    • luisestradaL Offline
                                      luisestrada @skyfall
                                      @skyfall I found this post exactly because of that icon, lol
                                      Have anyone made it work? changing fas to fal does the job for the Canadian maple leaf icon but breaks the others :(
                                        luisestrada @sdetweil
                                        @sdetweil said in Three module issues from a new user:
                                        // if there is a space in the name, ‘collectionname iconname’ use the string as is
                                        // for example “fa-brands fa-canadian-maple-leaf”
                                        symbol.className =(s.indexOf(’ ')>0?s:( “fas fa-fw fa-” +s));
                                        This works perfectly in calendar, however in the CX3 module it does not work, apparently spaces are not allowed
                                        kayakbabeK 1 Reply Last reply Reply Quote 0
                                        • kayakbabeK Offline
                                          kayakbabe @luisestrada
                                          it would have been nice if the fontawesome 4 prefixes weren’t hardcoded into the module sources/templates. Would have made changing the icons to something else in so much easier.
                                            luisestrada @kayakbabe
                                            @kayakbabe I agree.
                                            I went to line 448 and 449 of MMM-CalendarEXT3.js and edited this
                                                    exDom.classList.add('symbol', 'fa-solid')
                                                    exDom.classList.add(...event.symbol.map((s) => {return 'fa-' + s}))
                                            I did it once but since the update I had to reinstall the whole MagicMirror and lost the changes, I did not realized I did not backup that part of the code. I don’t remember what I did but I removed fa-solid and made something that changes fas and fab. based on config.js.
                                            Very similar of what it’s explain on this topic, but I can’t make it work anymore. Sorry for diverting the thread. We should talk about this on a new post as I’m talking about an extension.
                                            FontAwesome is already at version 6. It would be nice if MagicMirror in the future considers a flexible version in case of future updates, where you can choose in config.js if you want “fas” (by default) of “fab” :beaming_face_with_smiling_eyes:
                                            • luisestradaL luisestrada referenced this topic on
