    "Line 110 column 1: Parsing error: Unexpected token if" i dont know what to do
    3 Posts 2 Posters 1.0k Views 2 Watching
      anajorgesa
      when i tried to open my magic mirror it detected some errors, I’ve corrected everything I noticed but when I check the config file it keeps showing me the same error but I’m not supposed to edit that part. I’ve tried a lot of things but nothing seems to work so I don’t know what to do anymore .
      This is what it’s telling me :
      anajorgesa@raspberrypi:~/MagicMirror $ npm run config:check
      magicmirror@2.19.0 config:check
      node js/check_config.js
      [30.04.2022 14:30.53.426] [INFO] Checking file… /home/anajorgesa/MagicMirror/config/config.js
      [30.04.2022 14:30.53.480] [ERROR] Your configuration file contains syntax errors :(
      [30.04.2022 14:30.53.481] [ERROR] Line 110 column 1: Parsing error: Unexpected token if
      This is what I have :
      /* MagicMirror² Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-US",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "weather",
      				type: "current",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "YOUR_OPENWEATHER_API_KEY"
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true,
        sdetweil @anajorgesa
        @anajorgesa
        1st, always put config or code in code block
        paste, select pasted code
        hit the button over the edtor </>
        last… you are missing a }
        after the last } on line 109, just before the comment start /****
        the error says line 110, so look at the line before (exclude comments… )
        its ]
        and nothing ends with ]
          anajorgesa @sdetweil
          @sdetweil thank you , it’s working
