    MM Restarts on Pi4
    7 Posts 2 Posters 972 Views 2 Watching
    • T Offline
      thad @sdetweil
      pi@raspberrypi:~ $ ls ~/.pm2
      dump.pm2 dump.pm2.bak logs module_conf.json modules pids pm2.log pub.sock rpc.sock touch
      The SD card is probably a couple of years old.
        sdetweil @thad
        @thad weird…
        looks like pm2 is messed up
        let’s do this
        pm2 delete 0
        to get rid of the saved task
        them
        pm2 unstartup
        it will give u a command to copy/paste on the command line. do that…
        then reboot.
        pm2 is gone, so nothing will start
        then run the fixuppm2 script from my scripts repo
        see the last entry copy/paste
        MagicMirror should start
        then reboot to see if pm2 starts mm at boot time
        • T Offline
          thad @sdetweil
          Good news, bad news…
          Everything worked great until the last reboot. Post reboot, the MM restarting every minute starts again.
          Another observation, while running the fixuppm2 script I get those odd warnings:
          Accessing non-existent property ‘pwd’ of module exports inside circular dependency
          Several months ago, January I think, you helped me with the gpu related restarting. Once we got that working I don’t think the Pi4 rebooted until last week. I have very stable power and it’s plugged into a UPS. I think this problem may have been laying dormant for a long time.
          If you have other things you want me to try, let me know. For right now I have it working and I know the procedure to get it working again if I have to reboot for any reason.
            sdetweil @thad
            @thad how about node -v
            looks like u are on node 14.
            • T Offline
              thad @sdetweil
              pi@raspberrypi:~ $ node -v
              v16.13.2
