    NPM Vulnerabilities Alert.
    9 Posts 3 Posters 1.9k Views 3 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil That MMM-MoonPhase module just seems hugely bloated compared to the rest of the modules. It’s like writer used some pre-built package to write module and most of it is not being used.
      Was wondering how to remove some of that, I know how to comment out a line of code. Is there a way to do same but at the directory level?
      It runs so probably not worth the effort.
      • mumblebajM Offline
        mumblebaj Module Developer @ankonaskiff17
        @ankonaskiff17 The module has loads of dev dependencies. You should probably only install prod.
          "name": "MMM-MoonPhase",
          "version": "1.0.1",
          "description": "Todo: Insert description here!",
          "main": "MMM-MoonPhase.js",
          "author": "Nolan Kingdon",
          "license": "MIT",
          "devDependencies": {
            "grunt": "latest",
            "grunt-eslint": "latest",
            "grunt-jsonlint": "latest",
            "grunt-markdownlint": "^1.0.13",
            "grunt-stylelint": "latest",
            "grunt-yamllint": "latest",
            "stylelint-config-standard": "latest",
            "time-grunt": "latest"
          sdetweil @mumblebaj
          @mumblebaj via
          npm install --only=prod --omit=dev
          the 1st (–only=prod) is the old way
          migrating to the new way (–omit=dev)
          both are accepted
          ankonaskiff17A 1 Reply Last reply Reply Quote 1
            @sdetweil Can I do that retroactively or delete module then reinstall with npm install --omit=dev and that will get rid of unused directories/files?
            I should be able to just delete module & no need to mess with config.js or custom.css if that is route to take?
              sdetweil @ankonaskiff17
              @ankonaskiff17 yes just delete the node modules folder in the module folder and redo the npm install
              no guarantee it will change the results
              best just to ignore the messages
