    Need help with new Modul "Scare"
    8 Posts 2 Posters 1.1k Views 2 Watching
      sdetweil @Rattenjunge8080
      @Rattenjunge8080 said in Need help with new Modul "Scare":
      “Scare”
      the modulename
      module: “Scare”.
      the folder name
      modules/Scare
      and the filename
      Scare.js
      AND the register
      Module.register(“Scare”, {
      must all match exactly
      MagicMirror does not consider it an error if it can’t find the file…
      also, getdom MUST return something, at min and empty div
      you can debug the code by using the developers window, sources tab
      ctrl-shift-i to open (or close) the developers window
        Rattenjunge8080 @sdetweil
        hey, thanks for the fast reply!
        Modulename, registering it, making it availeble on the config file is not the problem. The problem is Javascript.
        As you can see, it is written in pseudocode and i need the correct expressions…
        You are right with the getDom, I will add a return value at the end, an empty div-container is created in the default-part.
        it looks now like this:
        	getDom: function(){
        	    // pseudocode TODO: How to check if the module was called by MMM-remote that it is visible?
        	    if(this.isVisible() {
        		showImageAndPlaySound();
        	    else{
        		//When the Module is not shown, then remove the 2 Images
        		this.container.removeChild(image1);
        		this.container.removeChild(image2);
        	    return this.container;
        Can you help me with the showImageAndPlaySound(); method? and how do i detect if the module is made visible/shown?
        Thanks a lot!
          @Rattenjunge8080
          see my SampleModule, which implements the spec, https://docs.magicmirror.builders/development/introduction.html
          https://github.com/sdetweil/SampleModule
          the suspend and resume methods are hide and show
            @sdetweil sorry, this is also not working.
            I used your SampleModule (named it helloworld and it shows everything on the screen) and did this to resume and suspend:
            	// system notification your module is being hidden
            	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
            	suspend: function(){
            		console.log('suspend');
            		Log.log("suspend");
            	// system notification your module is being unhidden/shown
            	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
            	resume: function(){
            		console.log('resume');
            		Log.log("resume");
            When I now do a npm start dev the console is not showing the logs from the resume and suspend function when I Show and Hide the module by Remote or API-Call:
            This logging works fine in other modules…
            Any ideas?
              @Rattenjunge8080 there is a helloworld already
              did u change all the places for ‘SampleModule’
              folder, filename and register?
                @sdetweil omg…I’am so incredible stupid…I named your module “helloworld”, forgot that of course there is a default module named “helloworld”…
                it is working, i see the resume and suspend logs.
                Ok, i will try to work on that Javascript code.
                Thanks for the help!
                  Rattenjunge8080
                  @Rattenjunge8080 So, i found a Solution, if anyone is interested, be my guest to copy this (spaghetti-code! I catch exceptions cause i am not able to check if and how many pictures are already loaded):
                  /* MagicMirror²
                   * Module: Scare
                   * By Rattenjunge8080
                  Module.register("Scare", {
                  	// Default module config.
                  	defaults: {
                  	start: function(){
                  		//The container which will be shown in DOM
                  		this.container = document.createElement("div");
                  		this.visible = true;	//set true via resume
                  		this.blocker = false; 	//block multiple DOM-calls
                  		image1 = document.createElement("img");
                  		image1.src = '/modules/Scare/img1.jpg';
                  		image1.classList.add("image1");
                  		image2 = document.createElement("img");
                  		image2.src = '/modules/Scare/img2.jpg';
                  		image2.classList.add("image2");
                  		this.visible = false;
                  		this.updateDom(1000);
                  		//TODO If in future not all pictures are removed->Delete the container:
                  		//this.container.remove();
                  	resume: function(){
                  		//TODO If in future not all pictures are removed->add here the container:
                  		//this.container = document.createElement("div");
                  		this.updateDom();
                  	 * Here the first Image will be added to a container, shown on screen
                  	 * and a timer will count down. Let them feel safe for a while...
                  	 * then a new image will pop up and a sound is played
                  	showImageAndPlaySound() {
                  	  this.blocker = true;
                  	  //TODO: Maybe useful in future
                  	  //this.container.innerHTML = "<img src=\"/modules/Scare/OVAL.png\" width=\"200px\" height=\"500px\">";
                  	  //Put in picture to let it print on DOM
                  	  this.container.appendChild(image1);
                  	  this.updateDom();
                  	  console.log("set timeout 10s");
                  	  try {
                  		setTimeout(() => this.container.removeChild(image1), 10000);
                  	  }catch (e) {console.log("catch timeout line 70");}
                  	  setTimeout(() => this.container.appendChild(image2), 10000);
                  	  this.updateDom();
                  	  //Generate the Audio from local file   TODO auch mit setTimeout machen
                  	  var audio = new Audio("/modules/Scare/sound.mp3");
                  	  audio.play();
                  	getDom: function(){
                  		if(this.visible){
                  			if(this.blocker === false){
                  				this.showImageAndPlaySound();
                  			}else{}
                  		}else{
                  			try {
                  			catch (e) {console.log("catch remove child img 1");}
                  			try {
                  			}catch (e) {console.log("catch remove child img 2");}
