    Need help with new Modul "Scare"
    8 Posts 2 Posters 1.1k Views 2 Watching
      sdetweil @Rattenjunge8080
      @Rattenjunge8080
      see my SampleModule, which implements the spec, https://docs.magicmirror.builders/development/introduction.html
      https://github.com/sdetweil/SampleModule
      the suspend and resume methods are hide and show
        Rattenjunge8080 @sdetweil
        @sdetweil sorry, this is also not working.
        I used your SampleModule (named it helloworld and it shows everything on the screen) and did this to resume and suspend:
        	// system notification your module is being hidden
        	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
        	suspend: function(){
        		console.log('suspend');
        		Log.log("suspend");
        	// system notification your module is being unhidden/shown
        	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
        	resume: function(){
        		console.log('resume');
        		Log.log("resume");
        When I now do a npm start dev the console is not showing the logs from the resume and suspend function when I Show and Hide the module by Remote or API-Call:
        This logging works fine in other modules…
        Any ideas?
          @Rattenjunge8080 there is a helloworld already
          did u change all the places for ‘SampleModule’
          folder, filename and register?
            @sdetweil omg…I’am so incredible stupid…I named your module “helloworld”, forgot that of course there is a default module named “helloworld”…
            it is working, i see the resume and suspend logs.
            Ok, i will try to work on that Javascript code.
            Thanks for the help!
              Rattenjunge8080
              @Rattenjunge8080 So, i found a Solution, if anyone is interested, be my guest to copy this (spaghetti-code! I catch exceptions cause i am not able to check if and how many pictures are already loaded):
              /* MagicMirror²
               * Module: Scare
               * By Rattenjunge8080
              Module.register("Scare", {
              	// Default module config.
              	defaults: {
              	start: function(){
              		//The container which will be shown in DOM
              		this.container = document.createElement("div");
              		this.visible = true;	//set true via resume
              		this.blocker = false; 	//block multiple DOM-calls
              		image1 = document.createElement("img");
              		image1.src = '/modules/Scare/img1.jpg';
              		image1.classList.add("image1");
              		image2 = document.createElement("img");
              		image2.src = '/modules/Scare/img2.jpg';
              		image2.classList.add("image2");
              		this.visible = false;
              		this.updateDom(1000);
              		//TODO If in future not all pictures are removed->Delete the container:
              		//this.container.remove();
              	resume: function(){
              		//TODO If in future not all pictures are removed->add here the container:
              		//this.container = document.createElement("div");
              		this.updateDom();
              	 * Here the first Image will be added to a container, shown on screen
              	 * and a timer will count down. Let them feel safe for a while...
              	 * then a new image will pop up and a sound is played
              	showImageAndPlaySound() {
              	  this.blocker = true;
              	  //TODO: Maybe useful in future
              	  //this.container.innerHTML = "<img src=\"/modules/Scare/OVAL.png\" width=\"200px\" height=\"500px\">";
              	  //Put in picture to let it print on DOM
              	  this.container.appendChild(image1);
              	  this.updateDom();
              	  console.log("set timeout 10s");
              	  try {
              		setTimeout(() => this.container.removeChild(image1), 10000);
              	  }catch (e) {console.log("catch timeout line 70");}
              	  setTimeout(() => this.container.appendChild(image2), 10000);
              	  this.updateDom();
              	  //Generate the Audio from local file   TODO auch mit setTimeout machen
              	  var audio = new Audio("/modules/Scare/sound.mp3");
              	  audio.play();
              	getDom: function(){
              		if(this.visible){
              			if(this.blocker === false){
              				this.showImageAndPlaySound();
              			}else{}
              		}else{
              			//When the Module is not shown, then remove the 2 Images
              			try {
              				this.container.removeChild(image1);
              			catch (e) {console.log("catch remove child img 1");}
              			try {
              				this.container.removeChild(image2);
              			}catch (e) {console.log("catch remove child img 2");}
              		return this.container;
