    MMM-SelfieShot: Rotating camera
    11 Posts 3 Posters 6.6k Views 3 Watching
    • H
      hclaus
      Hey everyone,
      MMM-Selfieshot only allows for an image preview in landscape mode. Is there a way/ unconventional configuration option to change into portrait mode?
      This would come quite handy as my mirror (as most mirrors) is also in portrait orientation and I am building a 3D-printed socket that also allows to put the camera into portrait orientation.
      Best,
      Hendrik
      M 1 Reply Last reply
        MMRIZE @hclaus
        @hclaus
        This module’s features are dependent on node_webcam module, but that module is just a convenient wrapper of lower-level applications like fswebcam or ImageSnap. Anyway, node_webcam itself has no feature about it.
        Frankly said, I’ve already requested that feature to the developer of that node module (https://github.com/chuckfairy/node-webcam/issues/38) for my own purpose, but he hadn’t yet.
        There could be several solutions;
        • Rotating the picture on display of MM (Just with CSS it could be done, but the file itself is not rotated, so if what you need is the picture itself, this is not a perfect solution)
        • Rotating the picture file after shooting (Another post-process is needed. Fortunately, Just one picture’s rotating takes not so long time - Some SBC might not have enough power to process fast)
        • Taking photo itself with rotation. (To achieve this, Independence from node_webcam module might be needed. But not a big deal.)
        I’ll consider options and make a solution for this.
        But you need to know one thing. At this moment, the module’s owner is in anotherone, not me. So I’ll make a PR but acceptance would be on his hands. (Maybe we could have other branch or special dedicated clone for you when the PR is not accepted.)
        H 1 Reply Last reply
        • H
          hclaus @MMRIZE
          @MMRIZE
          Thanks for your reply! I should maybe clarify:
          • The camera chip is mounted 90° rotated, so that I can make use of the maximum resolution of the camera chip in portrait mode.
          • The post-selfie view should ideally be rotated in the same direction as the camera (90° clockwise or counter-clockwise). Both is possible because I can 3D-print a suitable casing in both directions if necessary :-)
          • Rotating the picture file after shooting is not necessary. I do it manually or with another program.
          M 2 Replies Last reply
            MMRIZE @hclaus
            @hclaus
            So what you need is just displaying picture on mm screen with 90 CW/CCW rotation, I think it could be done with CSS only. I’ll test and show you how to do in a while. (I have dinner now ;) )
              MMRIZE @hclaus
              @hclaus
              custom.css
              #SELFIE .result {
                width: auto;
                height: auto;
                aspect-ratio: 1 / 1;
              @media (min-aspect-ratio: 1 / 1) { /* Horizontal Screen */
                #SELFIE .result {
                  left: calc((100vw - 90vh) / 2);
                  transform: rotate(90deg);
                  width: 90vh;
                  top: 0;
              @media (max-aspect-ratio: 1 / 1) { /* Vertical Screen */
                #SELFIE .result {
                  top: calc((100vh - 90vw) / 2);
                  height: 90vw;
                  left: 0;
              You can adjust some values for your purpose.
              S M 2 Replies Last reply
                sdetweil @MMRIZE
                @MMRIZE said in MMM-SelfieShot: Rotating camera:
                height -width?
                  MMRIZE @sdetweil
                  Yes, It works. Guess it. :)
                    sdetweil @MMRIZE
                    @MMRIZE hm… on my 2560wx1080h, top is -612
                    on my 3840wx2160h, top is -648
                    ((12160) -(.93840))/2
                      MMRIZE @sdetweil
                      It would be rotated.
                      2560w x 1080h
                      that is horizontal resolution, so by media rule; below will be adopted;
                      left: calc((100vw - 90vh) / 2); /* (2560 - 972) / 2 = 794 */
                      width: 90vh; /* 972 */
                      height: (auto) /* 972, by aspect-ratio: 1 / 1; */
                      top: 0;
                        sdetweil @MMRIZE
                        @MMRIZE ok, got it…
                          MMRIZE @MMRIZE
                          @hclaus
                          Anyway, this is a universal solution, because I don’t know your screen resolution, direction, background padding/margin, wanted photo size, etc.
                          With specific conditions, it would be deadly simpler.
