    Pi Zero as MagicMirror Client
    5 Posts 3 Posters 1.9k Views 3 Watching
      Jan 0
      Hey,
      I found an old Pi Zero (not the Pi Zero 2) and wanted to use it as a client for a MagicMirror. The server is running fine. I can access the MM from another computer.
      Now, I started the the Pi Zero (bullseye with desktop) and called the MM page in chromium. However, it is too slow: the page is not completely loaded, the clock is not running smoothly.
      Does anyone know of a better solution (browser options, another browser, less resource usage, …) on a Pi Zero?
      Thanks,
      Jan
        sdetweil @Jan 0
        @Jan-0 increase the swap space
        J 1 Reply Last reply
          Jan 0 @sdetweil
          @sdetweil Thanks for the hint. That improved the situation a lot but it is still not sufficient. I have different pages rotating every 10 seconds and I guess that’s too resource consuming. The CPU is 100 % used now.
          Perhaps, I need to wait until the PI Zero 2 is available again (at a reasonable price).
            sdetweil @Jan 0
            @Jan-0 yes redraw lots of pages is pretty taxing…
            you could try one of the other browsers.
            firefox, midori, puffin
            https://www.google.com/search?q=best+web+browsers+for+raspberry+pi
              dushyantahuja
              Try using FullPageOS
              https://github.com/guysoft/FullPageOS
              It works fine on a pi zero.
