    Magic Mirror - RTSP not integrated
    31 Posts 5 Posters 14.6k Views 6 Watching
    • BKeyportB Offline
      BKeyport Module Developer @MMRIZE
      @MMRIZE I would be happy to test when I get back home in a week. I’m out of town on business.
      plainbrokeP BKeyportB 2 Replies Last reply Reply Quote 0
      • plainbrokeP Offline
        plainbroke @BKeyport
        @MMRIZE
        I will be happy to test when I get back home. You have my email already.
        Send me a link or whatever so I can try it when I get back or if can get this chrome book changed over so i can run a MagicMirror on it…
          plainbroke @plainbroke
          @MMRIZE
          Hey I am back where I can test this RTSP module you have whipped up…
          Heck I would be fine if I could get RTSPStream to work with vlc since I use full screen when the camera feeds come around in the MMM-Carousel module.
          email same as user @gmail.com. What you are showing would be great if I can use it at full screen above or something like that…
            @BKeyport
            Where can I get your blank space module and the whatever Player you use?
            • BKeyportB Offline
              BKeyport Module Developer @plainbroke
              @plainbroke the blank space module is “MMM-Block” - on the 3rd party module list.
              I then use OMX, so you have to use either pre-current RPI OS, or figure out how to install it, as it’s abandon-ware.
                @BKeyport
                I have been looking at both and neither will work with my MM.
                I thank you for the information though I thought for a bit I could make it work, but I finally just gave up. My head was hurting from all the reading and searching to get it all to work. You must have the patients of Job to get that to work. More likely you understand code WAY better than I do… All this code is way above my understanding…
                  plainbroke
                  @MMRIZE ,
                  You get that RTSP module to work yet. I am very interested in it since MMM-RTSPStream has quit working altogether for me.
                  Not sure what I did different this time but even vlc fails to show a picture…
                    MMRIZE @plainbroke
                    @plainbroke
                    I’m still testing for optimal setting of rpi3. My approach(real time transcoding rtsp 2 mpeg to be implemented on html) seems somewhat burden for weak/old SBCs. Other more powered devices have enough to deal however. I’m not using rpi3 anymore, but not everyone.
                    Anyway I’m in summer leaves, so not have time at this moment. Maybe after 2 weeks I’ll continue. Plz wait a while.
                      plainbroke @MMRIZE
                      @MMRIZE
                      That is great to know. Thanks for the update, no worries.
                      I actually have RTSPStream up and running now using VLC.
                      So I am in no rush.
                      • BKeyportB Offline
                        @mmrize It working perfectly within my mirror, other than occasional pauses in stream… I use a PI4, and I’m currently in a heat wave, so it’s not running at full bore (I don’t have AC where the mirror is)
                        – edit:
                        OK - after a bit of burn-in, it’s falling all over itself. :(
                        I think I’d be better off using snapshots. Problem is, only module I can find that can work with the snapshot system of my camera is RTSPStream, which just blows chunks otherwise.
                          @BKeyport @MMRIZE
                          I went back to Buster (10) and my Mirror with rtspstream is working great now. Using OMXplayer. I will stick with buster until someone can get rtsp to work with bullseye (11) or whatever 12 is going to be called when it comes out…
                          • BKeyportB Offline
                            @plainbroke I’m on Buster. RTSPStream blows chunks all over the place. MMRize’s module is better, but sadly, I don’t think the Pi’s have enough power to handle my stream effectively, and I can’t turn it down.
                            If I could do the re-encoding on a dedicated pi or something, it could work…
                              MMRIZE @BKeyport
                              @BKeyport
                              Yup, My approach has looked so quite promising, but the usual RPI has not had enough power to deal. I haven’t tested RPI4 yet, but even RPI3B+ couldn’t; this approach would not be a general solution at that point. I was so disappointed.
                              The dead points I found were these;
                              • HTML5 on Chrome(Chromium) cannot handle any standard LIVE Streaming format itself by default. (What a surprise!), It means additional player components are needed.(I tried to use JSMPEG and WebSocket.) It takes some resources.
                              • FFmpeg (or VLC) is needed to transcode RTSP to MPEG in the background. It is not light process for RPI.
                              Normal PC (and some modern powerful SBCs) easily handle these works, but not RPI3. So I am stopping the project at this moment. I wish I have a better idea about this thing.
                              Thanks guys.
                              • BKeyportB Offline
                                @MMRIZE Thanks for the attempt. We’ll get there, somehow.
                                  @MMRIZE
                                  Darn, I am on a RPi 4 with 8gb ram, it has a 120gb ssd on a x825 expansion board. I think it should have enough umph to run a lot more than it does. Any chance I can get a preview of the module you where working on.?
                                  @BKeyport
                                  Maybe my setup is why RTSPStream seems to work well for my 5 different wyze cams that I am streaming from. I only stream one at a time and only for 45 seconds at a time, but they show up in a few seconds running MMM-Carousel as the page viewer. VLC works ok but takes way too long to populate and then I can’t control the size/zoom not sure which, So I only get part of the cameras view.
                                  So I guess I will stick with RTSPStream until one of these guinues coders come up with something that works better…
                                  I appreciate the effort @MMRIZE
                                  • BKeyportB Offline
                                    @plainbroke https://github.com/MMRIZE/MMM-RTSP is where he kept his attempt.
                                    It’s still there for now. :)
                                    plainbrokeP 2 Replies Last reply Reply Quote 0
                                      @BKeyport
                                      Thank you.
                                      • L Offline
                                        Laz
                                        I also have a problem displaying the flow from the MMM-RTSPStream module after turning on the screen on the motion sensor. The stream image does not return to the frame of the desired location. Was it possible to somehow defeat the image shift? I know that the module is no longer supported, but maybe who was able to find a solution? ((
                                        This is the kind of screen I have after the motion sensor is triggered… (((
                                        https://forum.magicmirror.builders/topic/17389/the-problem-of-displaying-the-flow-from-the-mmm-rtspstream-module-after-turning-on-the-screen-by-the-motion-sensor
                                        • BKeyportB Offline
                                          BKeyport Module Developer @Laz
                                          @Laz If you’re using VLC, likely not. There’s too many programs being run to make it work.
                                            @BKeyport said in Magic Mirror - RTSP not integrated:
                                            Hey,
                                            I pulled that to my mirror but all I get is the header. Which tells me I have something wrong in my config file but, He did not put much for how to setup the config file… I know the module is working since it shows the header on my mirror, just not the actual rtsp of the camera.
                                            Do you have time to show me what I need to setup in the config file?
                                            Here is what I put in my config.js file.
                                                    module: "MMM-RTSP",
                                                    position: "middle_center",
                                                    header: "RTSP - Garage",
                                                            streams: [
                                                            rtsp: "rtsp://admin:admin@192.168.1.35:554/live",
        wsPort: 2000, // should be unique.
        startStreamId: 1,
