    Need some help installing on Win10
    12 Posts 2 Posters 4.3k Views 2 Watching
      sdetweil @CheapDad
      @CheapDad yes npm screwed it up for windows.
      change each / to \\
      on the start clause unedited the display off of
        CheapDad @sdetweil
        @sdetweil Sam, add the display entries back in? Otherwise, is this correct?
        	"start": "node_modules\\.bin/electron js\\electron.js",
        		"start:dev": "node_modules\\.bin/electron js\\electron.js dev",
          sdetweil @CheapDad
          @CheapDad said in Need some help installing on Win10:
          “start”: “node_modules\\.bin/electron js\\electron.js”,
          all of the \
          u missed the bin/electron
            CheapDad @sdetweil
            @sdetweil Sam, I made those corrections and edited the config.js. I commented out all of the modules except the clock. (My intent is to only have one module, not yet installed, running.)
            When I did an npm start with only the sample config.js present, I got a black screen. I could press “alt” to get to the “File” menu and close MM.
            When I ran MM from Git BASH, I got another black screen, except this time “alt” did not do anything. “alt” and “esc” would minimize MM, but that’s it. Here’s what GIT BASH displays when I ran npm start with my edited config.js:
            $ npm start
            npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
            > magicmirror@2.20.0 start
            > node_modules\.bin\electron js\electron.js
            [09.08.2022 20:50.32.077] [LOG]   Starting MagicMirror: v2.20.0
            [09.08.2022 20:50.32.082] [LOG]   Loading config ...
            [09.08.2022 20:50.32.091] [LOG]   Loading module helpers ...
            [09.08.2022 20:50.32.092] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading 'split')
            [09.08.2022 20:50.32.093] [LOG]   Loading module helpers ...
            [09.08.2022 20:50.32.094] [ERROR] App threw an error during load
            [09.08.2022 20:50.32.095] [ERROR] TypeError: Cannot read properties of undefined (reading 'split')
                at loadModule (C:\Users\Hannah\magicmirror\js\app.js:108:27)
                at loadNextModule (C:\Users\Hannah\magicmirror\js\app.js:165:5)
                at loadModules (C:\Users\Hannah\magicmirror\js\app.js:176:3)
                at C:\Users\Hannah\magicmirror\js\app.js:225:4
                at loadConfig (C:\Users\Hannah\magicmirror\js\app.js:81:4)
                at App.start (C:\Users\Hannah\magicmirror\js\app.js:212:3)
                at Object.<anonymous> (C:\Users\Hannah\magicmirror\js\electron.js:159:7)
                at Module._compile (node:internal/modules/cjs/loader:1118:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
                at Module.load (node:internal/modules/cjs/loader:988:32)
            [09.08.2022 20:50.32.097] [ERROR] Whoops! There was an uncaught exception...
            [09.08.2022 20:50.32.101] [ERROR] TypeError: Cannot read properties of undefined (reading 'split')
            [09.08.2022 20:50.32.103] [ERROR] MagicMirror┬▓ will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [09.08.2022 20:50.32.104] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [09.08.2022 20:50.32.201] [LOG]   Launching application.
            [11036:0809/205232.493:ERROR:gpu_init.cc(481)] Passthrough is not supported, GL is disabled, ANGLE is
              sdetweil @CheapDad
              @CheapDad usually this is a bad position string
                CheapDad @sdetweil
                @sdetweil said in Need some help installing on Win10:
                Sam, my apologies but I have no idea what this means. A google search didn’t reveal anything that appeared to be on point either.
                  sdetweil @CheapDad
                  @CheapDad
                          module: ",,,,,,",
                          position: "xxx_yyy",   <----- that thing  (the 'position' string
                  or mis-spelling ‘position’
                    CheapDad @sdetweil
                    @sdetweil Thank you! Two other questions:
                    1. I assume that since this latest black screen occurred after I used my edited config.js, that’s where I need to look for the error. Correct?
                    2. Once that correction is made, should I then see the MM running in a window? I ask because I had received a black screen previously using the sample config.js
                      sdetweil @CheapDad
                      @CheapDad you did the two extra steps to install in fonts and vendor , right?
                      the sample config should work unchanged
                      it should be the same as on linux… full screen…
                        CheapDad @sdetweil
                        @sdetweil I didn’t do the extra steps. I was hoping to get the confirmation that I needed a working config.js that the walkthrough speaks about. I’ll run those extra steps.
