    Need some help installing on Win10
    12 Posts 2 Posters 4.5k Views 2 Watching
      sdetweil @CheapDad
      @CheapDad usually this is a bad position string
        CheapDad @sdetweil
        @sdetweil said in Need some help installing on Win10:
        Sam, my apologies but I have no idea what this means. A google search didn’t reveal anything that appeared to be on point either.
          sdetweil @CheapDad
          @CheapDad
                  module: ",,,,,,",
                  position: "xxx_yyy",   <----- that thing  (the 'position' string
          or mis-spelling ‘position’
            CheapDad @sdetweil
            @sdetweil Thank you! Two other questions:
            1. I assume that since this latest black screen occurred after I used my edited config.js, that’s where I need to look for the error. Correct?
            2. Once that correction is made, should I then see the MM running in a window? I ask because I had received a black screen previously using the sample config.js
              sdetweil @CheapDad
              @CheapDad you did the two extra steps to install in fonts and vendor , right?
              the sample config should work unchanged
              it should be the same as on linux… full screen…
                CheapDad @sdetweil
                @sdetweil I didn’t do the extra steps. I was hoping to get the confirmation that I needed a working config.js that the walkthrough speaks about. I’ll run those extra steps.
                  sdetweil @CheapDad
                  @CheapDad see
                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
