Recurring calendar events are off by a day
7 Posts 2 Posters 1.8k Views 2 Watching
    justinreimer
    I’ve seen a number of discussions about this topic and have tried the fixes that I’ve been able to find, but I’m still running into cases where weekly recurring events on my ical are showing up a day late.
    I believe I have set my system timezone, locale, and keyboard correctly.
    I have upgraded to the lates version of MagicMirror v2.20.0
    My timezone is PST
    Here is the VEVENT data associate with a dummy event that has this problem. When I entered this item into my calendar, I set it to happen on Thursday from 7:00PM to 7:15PM. Then I set it to be recurring. However on the MagicMirror, it shows up at 7:00 PM on Friday
    BEGIN:VEVENT
    CREATED:20220810T060530Z
    UID:029DDE3C-6248-442D-A1A1-51AB6421F5D2
    RRULE:FREQ=WEEKLY;INTERVAL=1
    DTEND;TZID=America/Los_Angeles:20220811T191500
    SUMMARY:This is a test Event
    LAST-MODIFIED:20220810T060608Z
    DTSTAMP:20220810T060608Z
    DTSTART;TZID=America/Los_Angeles:20220811T190000
    SEQUENCE:1
    END:VEVENT
    also, here is the config properties I have for the module
        fade: false,
        maxTitleLength: 50,
        wrapEvents: true,
        maximumEntries: 15,
        timeFormat: "absolute",
        colored: true,
        dateFormat: "hh:mma ddd MMM Do",
        fullDayEventDateFormat: "ddd MMM Do",
        getRelative: 0,
        urgency: 0
    @sdetweil I’m sure you’re sick of responding to these types of questions, but any ideas? You seem to be pretty involved in some of the other discussions I’ve seen on this issue.
    S 1 Reply Last reply Aug 10, 2022, 1:58 PM Reply Quote 0
      sdetweil @justinreimer
      @justinreimer yeh, SO much fun… looks like a chnage to the lower level lib has ‘fixed’ the problem I had to work around 3 years ago…
      so to test
      edit ~/MagicMirror/modules/default/calendar/calendarutils.js
      and coment out (add // to the beginning of the line)
      lines 338 and 350
      both say (one has a minus sign, one a plus sign before Math( )
      	date = new Date(date.getTime() - Math.abs(24 * 60) * 60000);
      and lines 366 and 378
              date = new Date(date.getTime() + Math.abs(24 * 60) * 60000);
      J 1 Reply Last reply Aug 11, 2022, 4:59 PM Reply Quote 0
        justinreimer @sdetweil
        So the good news is that commenting out the above lines did fix the issue with the event I posted about above.
        The bad news is that it caused issues with other events that were previously working.
        Here’s the VEVENT data associated with one of the newly mis-behaving events
        BEGIN:VEVENT
        CREATED:20220811T165129Z
        UID:C8B93B02-3057-41F6-A69A-F4959C342E02
        RRULE:FREQ=WEEKLY;INTERVAL=1;BYDAY=MO,WE
        DTEND;TZID=America/Los_Angeles:20220808T210000
        TRANSP:OPAQUE
        X-APPLE-TRAVEL-ADVISORY-BEHAVIOR:AUTOMATIC
        SUMMARY:My Custom Event
        LAST-MODIFIED:20220811T165146Z
        DTSTAMP:20220811T165147Z
        DTSTART;TZID=America/Los_Angeles:20220808T190000
        SEQUENCE:1
        END:VEVENT
        This new event that is now wrong is a weekly repeating event that is scheduled for every Monday and Wednesday at 7:00 PM. However, the calendar module on the Magic Mirror is now showing it happening every Sunday and Tuesday at 7:00 PM.
        S 2 Replies Last reply Aug 11, 2022, 5:39 PM Reply Quote 0
          @justinreimer that’s what I was afraid of.
          put them back. let me look at it some more
          thanks for the other event
            @justinreimer the problem is the library that handles the recurring events
            sometimes it gets its date/times messed up , the new event
            if got 2 events per week, BUT used the correct DATE and the UTC TIME, and THAT turns into the day before in LA timezone. which is what the code we commented out fixes…
            [11.08.2022 12:12.47.262] [DEBUG] start: Mon Aug 08 2022 19:00:00 GMT-0700 (Pacific Daylight Time)
            [11.08.2022 12:12.47.263] [DEBUG] end:: Mon Aug 08 2022 21:00:00 GMT-0700 (Pacific Daylight Time)
            [11.08.2022 12:12.47.264] [DEBUG] duration: 7200000
            [11.08.2022 12:12.47.264] [DEBUG] title: My Custom Event
            [11.08.2022 12:12.47.265] [DEBUG] Search for recurring events between: Thu Aug 11 2022 12:12:47 GMT-0700 (Pacific Daylight Time) and Thu Aug 10 2023 23:59:59 GMT-0700 (Pacific Daylight Time)
            [11.08.2022 12:12.47.300] [DEBUG] Title: My Custom Event, with dates: ["2022-08-15T02:00:00.000Z","2022-08-17T02:00:00.000Z",
            except the 1st event
            [11.08.2022 12:12.46.698] [DEBUG] start: Thu Aug 11 2022 19:00:00 GMT-0700 (Pacific Daylight Time)
            [11.08.2022 12:12.46.698] [DEBUG] end:: Thu Aug 11 2022 19:15:00 GMT-0700 (Pacific Daylight Time)
            [11.08.2022 12:12.46.699] [DEBUG] duration: 900000
            [11.08.2022 12:12.46.699] [DEBUG] title: This is a test Event
            [11.08.2022 12:12.46.700] [DEBUG] Search for recurring events between: Thu Aug 11 2022 12:12:46 GMT-0700 (Pacific Daylight Time) and Thu Aug 10 2023 23:59:59 GMT-0700 (Pacific Daylight Time)
            [11.08.2022 12:12.46.782] [DEBUG] Title: This is a test Event, with dates: ["2022-08-12T02:00:00.000Z","2022-08-19T02:00:00.000Z",
            is processed correctly…
            unfortunately i cannot tell that one is ok, and the other is not.
            if u take off the BYDAY on the second event then its ok…
            hm… try this …
            uncomment, and add this line above each line you had commented out
              if(curEvent.rrule.origOptions.byweekday !== undefined)
            this checks to see if the vevent rrule explicitly specified byday… if so, it corrects…
            otherwise not
            seems to work for me
            J 1 Reply Last reply Aug 11, 2022, 7:58 PM Reply Quote 0
              @sdetweil Yep that seems to have fixed it. Checked the next 30 events on my calendar, and they all seem to match up now. Thanks!
              S 1 Reply Last reply Sep 5, 2022, 7:56 PM Reply Quote 0
                @justinreimer I have submitted fix https://github.com/MichMich/MagicMirror/pull/2905
                for the next release
                • A akriegshauser referenced this topic on Jan 11, 2023, 7:30 PM
                • O oldrocker referenced this topic on Nov 11, 2023, 6:05 PM
