    how to install specific version of magicmirror
    8 Posts 2 Posters 1.2k Views 3 Watching
    • T Offline
      tanvir586 @sdetweil
      @sdetweil is it automatic installation. Or I have to do it manually.
        sdetweil @tanvir586
        @tanvir586 manually
        • T Offline
          tanvir586 @sdetweil
          @sdetweil after I done
          git clone https://github.com/MichMich/MagicMirror
          Then git chackout 2.19.0 ?
          Sorry I’m bit confused here
            sdetweil @tanvir586
            @tanvir586 yes,
            git clone make a copy of the source repository on your machine
            the checkout command will make a particular commit active
            the label has to be exact
            git checkout v2.19.0
            now the MagicMirror working copy folder is the code at v2.19.0 level
              sdetweil @tanvir586
              @tanvir586 also see the options here
              https://www.techiedelight.com/clone-specific-tag-with-git/
              if u look at the MagicMirror repo on github
              you will see the drop-down next to master
              but also see the tags tab
              if u select the tags tab, then u see all the tags, one for each release
              • T Offline
                tanvir586 @sdetweil
                @sdetweil thanks 😊. Will try soon.
