    how to install specific version of magicmirror
    8 Posts 2 Posters 1.2k Views 3 Watching
      sdetweil @tanvir586
      @tanvir586 manually
      • T Offline
        tanvir586 @sdetweil
        @sdetweil after I done
        git clone https://github.com/MichMich/MagicMirror
        Then git chackout 2.19.0 ?
        Sorry I’m bit confused here
          sdetweil @tanvir586
          @tanvir586 yes,
          git clone make a copy of the source repository on your machine
          the checkout command will make a particular commit active
          the label has to be exact
          git checkout v2.19.0
          now the MagicMirror working copy folder is the code at v2.19.0 level
            sdetweil @tanvir586
            @tanvir586 also see the options here
            https://www.techiedelight.com/clone-specific-tag-with-git/
            if u look at the MagicMirror repo on github
            you will see the drop-down next to master
            but also see the tags tab
            if u select the tags tab, then u see all the tags, one for each release
            • T Offline
              tanvir586 @sdetweil
              @sdetweil thanks 😊. Will try soon.
