    how to install specific version of magicmirror
    8 Posts 2 Posters 1.6k Views 3 Watching
    • T Offline
      tanvir586
      magicmirror 2.19
        sdetweil @tanvir586
        @tanvir586
        git clone magic mirror repo, like always
        git checkout v2.19.0
        all releases are marked with tags
        • T Offline
          tanvir586 @sdetweil
          @sdetweil is it automatic installation. Or I have to do it manually.
            sdetweil @tanvir586
            @tanvir586 manually
            • T Offline
              tanvir586 @sdetweil
              @sdetweil after I done
              git clone https://github.com/MichMich/MagicMirror
              Then git chackout 2.19.0 ?
              Sorry I’m bit confused here
                sdetweil @tanvir586
                @tanvir586 yes,
                git clone make a copy of the source repository on your machine
                the checkout command will make a particular commit active
                the label has to be exact
                now the MagicMirror working copy folder is the code at v2.19.0 level
                  sdetweil @tanvir586
                  @tanvir586 also see the options here
                  https://www.techiedelight.com/clone-specific-tag-with-git/
                  if u look at the MagicMirror repo on github
                  you will see the drop-down next to master
                  but also see the tags tab
                  if u select the tags tab, then u see all the tags, one for each release
                  • T Offline
                    tanvir586 @sdetweil
                    @sdetweil thanks 😊. Will try soon.
