    Mirror not using my custom.css
    8 Posts 3 Posters 2.2k Views 4 Watching
      justdreambig
      So I have been working on this for a while and tried to google all the stuff and it got me really far but I am stuck on what i like to call the final yard…
      I am trying to change the font weight on .mmm-homeassistant-sensors . The module is running correctly but I can’t seem to get the mirror to see my custom changes.
      What I am working with:
      Synolgy NAS - Docker
      Image - bastilimbach/docker-magicmirror
      Here is what I have done so far: (Thank you to the forums for this)
      1. created a custom.css file and mounted the file with docker compose
      2. Checked the custom.css with docker exec cat and it returns what is in my custom.css file so I know it is avaiable to my mirror
      3. rebooted and rebuilt the container many times
      I inspeced the module with Chrome and it only shows main.css as the source so The only thing I can think of is my code is wrong. I tried reading the CSS 101 - Getting started with CSS and understanding how CSS works but man my head is spinning. Below is my code
      .mmm-homeassistant-sensors {
          font-weight:bold;
      Any help is appreciated… Thanks
        sdetweil @justdreambig
        @justdreambig the module name is MMM-homeassistant-senaors
        case matters
          justdreambig @sdetweil
          @sdetweil Thanks for your reply… I made the change and it didn’t work.
            @justdreambig ok, the open the developers window ctrl-shift-i , select the console tab and look thru the contents for a red error loading custom.css, unknown file type
            means didn’t find it in the correct location
            u can also examine the content element, select the elements tab, and the pointer top left of the dev window. navigate to the specific content element in the mm window, and click.
            the css tree is shown on right. if your css is used but not effective it will have a strike thru
              @sdetweil Oh man great directions… I made some tweaks to my code and I can now see that the browser is using the custom.css and it is working.
              Thanks for teaching me something new.
                @justdreambig see this for more
                https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1662487961519
                  @sdetweil I will check it out… Thanks!
                  • karsten13K Offline
                    karsten13 @justdreambig
                    @justdreambig
                    This docker image is not maintained anymore so you are using an old version of mm (the image was last updated 15 month ago).
