    MMM-News and BBC
    40 Posts 4 Posters 17.3k Views 4 Watching
      MMRIZE @DarrenHill
      @DarrenHill
      As one of original authors of that module (I have delegated all the authority to another developer) I’ll look inside in a few days.
      • mumblebajM
        mumblebaj Module Developer @DarrenHill
        @DarrenHill Hi. I just tested with your config and it works fine for me.
        I look after MMM-News which can be found here
          sdetweil @DarrenHill
          @DarrenHill what is your address: in mm config.js?
          have u changed it recently?
          does this module report errors in the console?
          might be a CORS error…
            DarrenHill @sdetweil
            Thanks gents. Nice to know support is still there.
            It was working a while back (several weeks) then it started showing images with #null and no other text, and now it doesn’t show anything in the area assigned to it.
            In mm-error.log after a reboot, all I see is this:
            [06.09.2022 20:13.58.974] [ERROR] Whoops! There was an uncaught exception...
            [06.09.2022 20:13.58.990] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                at Server.setupListenHandle [as _listen2] (node:net:1330:16)
                at listenInCluster (node:net:1378:12)
                at doListen (node:net:1516:7)
                at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
              code: 'EADDRINUSE',
              errno: -98,
              syscall: 'listen',
              address: '0.0.0.0',
              port: 8080
            [06.09.2022 20:13.58.992] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [06.09.2022 20:13.58.993] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [29786:0906/201403.366075:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            [29882:0906/201403.754866:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
            [29803:0906/201403.845480:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
            (I renamed the log file and started a fresh log file with a reboot, as the old one is large and full of stuff).
            The mirror has a static IP address which hasn’t changed, and I haven’t knowingly changed anything in the config, at least since the problem arose.
            Can you remind me how to access the console?
              @DarrenHill alt-spacebar, n
              MagicMirror is the app created by my install
              mm is the one created by following the manual instructions.
              pm2 stop all
              will stop everything
              pm2 info 0 (or name) will dump out the info about what is to be run…
              for MagicMirror it is /home/pi/MagicMirror/I stallers/mm.sh
              to delete an entry
              pm2 delete 0( or 1 or a name)
              then pm2 save to update the pm2 startup cache
              pm2 --help, like most Linux commands will tell you all the things it can do
                @sdetweil Thanks - I just found the wiki page about auto starting and saw I had somehow got it running twice.
                That’s now fixed, but after a reboot the module issue still remains.
                I’ll go check logs and console now.
                  @sdetweil OK I’ve found a News module error in the MagicMirror-out.log:
                  [06.09.2022 20:26.46.502] [LOG]   [NEWS] Error :  https://newsapi.org/v2/top-headlines?sources=bbc-news&pageSize=100&apiKey=<redacted> TypeError: Cannot read properties of undefined (reading 'toString')
                      at slugify (/home/pi/MagicMirror/modules/MMM-News/node_helper.js:24:17)
                      at cb (/home/pi/MagicMirror/modules/MMM-News/node_helper.js:89:33)
                      at getArticles (/home/pi/MagicMirror/modules/MMM-News/node_helper.js:135:22)
                      at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                  I’ve removed my API key string, but the rest is copy/paste.
                  I tried a git pull on the module the other day before my first post here, and it’s up to date.
                    @DarrenHill that error means the content back from the API is not as expected. either nothing there or the format changed.
                      @sdetweil OK, although from what @mumblebaj posted above it still works for him with my config?
                      I’ll try removing it and reinstalling it and see if that helps.
                        @DarrenHill not a reinstall thing
                          @sdetweil OK.
                          So I guess I’m stuck for now unless you or the others have any suggestions.
                          I was wondering as you say if the incoming info format had changed when it started throwing the #null text, but it’s weird that it works for others?
                            MMRIZE @DarrenHill
                            @DarrenHill
                            Well, I also tried your config with my apiKey and it worked.
                            Try this in your browser and let’s see what happens.
                            https://newsapi.org/v2/top-headlines?sources=bbc-news&pageSize=100&apiKey=YOUR_KEY
                              @DarrenHill ediut node_helper.js
                              insert this line
                                    console.log("fetch result=",result)
                              after line 128 so it looks like this
                                    var result = await response.json()
                                    return(result)
                              then rerun MM… best to stop using pm2 for all this
                              pm2 stop all
                              then
                              npm start >somefile.txt 2>&1
                              wait 15 seconds
                              ctrl-m to minimize MM
                              then ctrl-c on the terminal window you use to start MM
                              then edit somefile.txt
                              to look for status:
                              (ctrl-w in nano)
                              this is another dumb api… there is an error , but it doesn’t return it in the return code, but in the data!!!.. stupid…
                              for mine it says (with a bad key)
                              [06.09.2022 14:56.29.138] [LOG]   fetch result= {
                                status: 'error',
                                code: 'apiKeyInvalid',
                                message: 'Your API key is invalid or incorrect. Check your key, or go to https://newsapi.org to create a free API key.'
                                MMRIZE @MMRIZE
                                @MMRIZE said in MMM-News and BBC:
                                @DarrenHill
                                It should be like something similar to this(if your apiKey is valid);
                                {"status":"ok","totalResults":10,"articles":[{"source":{"id":"bbc-news","name":"BBC News"},"author":"BBC News","title":"Vaping: Juul to pay $438.5 m in youth marketing probe","description":"US prosecutors accuse the firm of \"relentlessly\" targeting underage buyers.","url":"http://www.bbc.co.uk/news/business-62813896","urlToImage":"https://ichef.bbci.co.uk/news/1024/branded_news/1F91/production/_126618080_323275f83124ee4f8c4cbed6b71c6807fe92d57c.jpg","publishedAt":"2022-09-06T19:52:21.045172Z","content":"Juul Labs will pay $438.5m (£380m) to end a probe of its advertising to underage buyers as it rose to be one of the top e-cigarette firms in the US.\r\nThe deal with 33 states and Puerto Rico also rest… [+1826 chars]"}, …
                                  DarrenHill @MMRIZE
                                  I get this, which looks slightly different to yours? :
                                  {"status":"ok","totalResults":10,"articles":[{"title":"Vaping: Juul to pay $438.5 m in youth marketing probe","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T19:52:21.045172Z","url":"http://www.bbc.co.uk/news/business-62813896"},{"title":"Eliza Fletcher: Police identify body found in search for heiress","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T16:52:18.6995928Z","url":"http://www.bbc.co.uk/news/world-us-canada-62811661"},{"title":"Ukraine war: Russians to pay €45 more to enter EU under new rules","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T16:37:23.3671715Z","url":"http://www.bbc.co.uk/news/world-europe-62811675"},{"title":"Fat Leonard: Malaysian businessman linked to US Navy scandal escapes","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T16:22:22.2671956Z","url":"http://www.bbc.co.uk/news/world-us-canada-62764226"},{"title":"Canada stabbings: Police hunt remaining suspect after Saskatchewan attacks","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T15:22:24.1190163Z","url":"http://www.bbc.co.uk/news/live/world-us-canada-62811629"},{"title":"Ukraine: Ben Stiller and Sean Penn latest Americans banned from Russia","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T12:52:14.8462267Z","url":"http://www.bbc.co.uk/news/world-europe-62806655"},{"title":"Canada stabbings: Relatives identify 'random' victims of Saskatchewan attack","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T11:07:21.1055569Z","url":"http://www.bbc.co.uk/news/world-us-canada-62804826"},{"title":"Liz Truss: Boris Johnson to give farewell speech before new PM takes office","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-06T04:37:21.3806544Z","url":"http://www.bbc.co.uk/news/live/uk-politics-62802807"},{"title":"Keith Davis: He was protecting the oceans - then he disappeared","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-05T20:52:23.0241991Z","url":"http://www.bbc.co.uk/news/world-us-canada-62603911"},{"title":"Timed Teaser: How did Putin mark Gorbachev's death?","author":"BBC News","source":{"Id":"bbc-news","Name":"BBC News"},"publishedAt":"2022-09-05T20:37:23.1798468Z","url":"http://www.bbc.co.uk/news/world-us-canada-62763889"}]}
                                  @sdetweil I’ll do your test now…
                                    MMRIZE @DarrenHill
                                    @DarrenHill
                                    Ok, I found something. I don’t know why, but your result has “articles.source.Name” instead of “articles.source.name” that makes this error.
                                    S D 2 Replies Last reply Reply Quote 0
                                      sdetweil @MMRIZE
                                      @MMRIZE yes, was just about to post that
                                        @sdetweil I get this (for the relevant bit):
                                        [06.09.2022 21:11.46.552] [LOG]   fetch result= {
                                          status: 'ok',
                                          totalResults: 10,
                                          articles: [
                                              title: 'Vaping: Juul to pay $438.5 m in youth marketing probe',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T19:52:21.045172Z',
                                              url: 'http://www.bbc.co.uk/news/business-62813896'
                                              title: 'Eliza Fletcher: Police identify body found in search for heiress',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T16:52:18.6995928Z',
                                              url: 'http://www.bbc.co.uk/news/world-us-canada-62811661'
                                              title: 'Ukraine war: Russians to pay €45 more to enter EU under new rules',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T16:37:23.3671715Z',
                                              url: 'http://www.bbc.co.uk/news/world-europe-62811675'
                                              title: 'Fat Leonard: Malaysian businessman linked to US Navy scandal escapes',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T16:22:22.2671956Z',
                                              url: 'http://www.bbc.co.uk/news/world-us-canada-62764226'
                                              title: 'Canada stabbings: Police hunt remaining suspect after Saskatchewan attacks',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T15:22:24.1190163Z',
                                              url: 'http://www.bbc.co.uk/news/live/world-us-canada-62811629'
                                              title: 'Ukraine: Ben Stiller and Sean Penn latest Americans banned from Russia',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T12:52:14.8462267Z',
                                              url: 'http://www.bbc.co.uk/news/world-europe-62806655'
                                              title: "Canada stabbings: Relatives identify 'random' victims of Saskatchewan attack",
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T11:07:21.1055569Z',
                                              url: 'http://www.bbc.co.uk/news/world-us-canada-62804826'
                                              title: 'Liz Truss: Boris Johnson to give farewell speech before new PM takes office',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-06T04:37:21.3806544Z',
                                              url: 'http://www.bbc.co.uk/news/live/uk-politics-62802807'
                                              title: 'Keith Davis: He was protecting the oceans - then he disappeared',
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-05T20:52:23.0241991Z',
                                              url: 'http://www.bbc.co.uk/news/world-us-canada-62603911'
                                              title: "Timed Teaser: How did Putin mark Gorbachev's death?",
                                              author: 'BBC News',
                                              source: [Object],
                                              publishedAt: '2022-09-05T20:37:23.1798468Z',
                                              url: 'http://www.bbc.co.uk/news/world-us-canada-62763889'
                                        [06.09.2022 21:11.46.635] [LOG]   [NEWS] Error :  https://newsapi.org/v2/top-headlines?sources=bbc-news&pageSize=100&apiKey=<redacted> TypeError: Cannot read properties of undefined (reading 'toString')
                                            at getArticles (/home/pi/MagicMirror/modules/MMM-News/node_helper.js:136:22)
                                          @DarrenHill said in MMM-News and BBC:
                                            source: [Object],
                                          its in there
                                            DarrenHill @MMRIZE
                                            @DarrenHill
                                            Anything I can do to overcome that?
                                            No idea why I’m getting different API returns to you guys…?
