    MMM-News and BBC
    40 Posts 4 Posters 13.4k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @DarrenHill
      @DarrenHill Hi. I just tested with your config and it works fine for me.
      I look after MMM-News which can be found here
        sdetweil @DarrenHill
        @DarrenHill what is your address: in mm config.js?
        have u changed it recently?
        does this module report errors in the console?
        might be a CORS error…
          DarrenHill @sdetweil
          Thanks gents. Nice to know support is still there.
          It was working a while back (several weeks) then it started showing images with #null and no other text, and now it doesn’t show anything in the area assigned to it.
          In mm-error.log after a reboot, all I see is this:
          [06.09.2022 20:13.58.974] [ERROR] Whoops! There was an uncaught exception...
          [06.09.2022 20:13.58.990] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
              at Server.setupListenHandle [as _listen2] (node:net:1330:16)
              at listenInCluster (node:net:1378:12)
              at doListen (node:net:1516:7)
              at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
            code: 'EADDRINUSE',
            errno: -98,
            syscall: 'listen',
            address: '0.0.0.0',
            port: 8080
          [06.09.2022 20:13.58.992] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [06.09.2022 20:13.58.993] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [29786:0906/201403.366075:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          [29882:0906/201403.754866:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          [29803:0906/201403.845480:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
          (I renamed the log file and started a fresh log file with a reboot, as the old one is large and full of stuff).
          The mirror has a static IP address which hasn’t changed, and I haven’t knowingly changed anything in the config, at least since the problem arose.
          Can you remind me how to access the console?
            @DarrenHill alt-spacebar, n
            MagicMirror is the app created by my install
            mm is the one created by following the manual instructions.
            pm2 stop all
            will stop everything
            pm2 info 0 (or name) will dump out the info about what is to be run…
            for MagicMirror it is /home/pi/MagicMirror/I stallers/mm.sh
            to delete an entry
            pm2 delete 0( or 1 or a name)
            then pm2 save to update the pm2 startup cache
            pm2 --help, like most Linux commands will tell you all the things it can do
              @sdetweil Thanks - I just found the wiki page about auto starting and saw I had somehow got it running twice.
              That’s now fixed, but after a reboot the module issue still remains.
              I’ll go check logs and console now.
                @sdetweil OK I’ve found a News module error in the MagicMirror-out.log:
                [06.09.2022 20:26.46.502] [LOG]   [NEWS] Error :  https://newsapi.org/v2/top-headlines?sources=bbc-news&pageSize=100&apiKey=<redacted> TypeError: Cannot read properties of undefined (reading 'toString')
                    at slugify (/home/pi/MagicMirror/modules/MMM-News/node_helper.js:24:17)
                    at cb (/home/pi/MagicMirror/modules/MMM-News/node_helper.js:89:33)
                    at getArticles (/home/pi/MagicMirror/modules/MMM-News/node_helper.js:135:22)
                    at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                I’ve removed my API key string, but the rest is copy/paste.
                I tried a git pull on the module the other day before my first post here, and it’s up to date.
                  @DarrenHill that error means the content back from the API is not as expected. either nothing there or the format changed.
                    @sdetweil OK, although from what @mumblebaj posted above it still works for him with my config?
                    I’ll try removing it and reinstalling it and see if that helps.
                      @DarrenHill not a reinstall thing
                        @sdetweil OK.
                        So I guess I’m stuck for now unless you or the others have any suggestions.
                        I was wondering as you say if the incoming info format had changed when it started throwing the #null text, but it’s weird that it works for others?
                        • 1 / 4
