    module MMM-APO
    8 Posts 2 Posters 941 Views 2 Watching
      jeromeguill
      hello I start with my magicmirror. I installed MMM-Apod. I can’t create an API key to retrieve images of the planet Mars, for example. Where can I find a tutorial?
        sdetweil @jeromeguill
        @jeromeguill from the module documentation
          jeromeguill
          it’s on the nasa site that I can’t create an API key with the image I want
          S 2 Replies Last reply Reply Quote 1
            @jeromeguill well, then I guess this module doesn’t work for you.
              @jeromeguill there are images of Mars
              Available Mars Mosaics, using the same API key
                jeromeguill
                I would simply like the way to be able to retrieve a specific image from the nasa site. Otherwise the module works but I would like another image
                  @jeromeguill
                  they give an example of specific images available
                  https://trek.nasa.gov/tiles/apidoc/trekAPI.html?body=mars
                    @jeromeguill the last two parameters described in the doc give u the ability to specify a specific image
