    IR Frame not responding while using MM
    4 Posts 2 Posters 580 Views 2 Watching
      CurlyQ12391
      Hello!
      I am running MM on a Roku TV with a pretty basic IR Frame that is very much “plug and play”. I initially had no problem with it responding while MM was running but after having to re-flash rasbian and re-configure MM it doesn’t seem to work.
      The screen DOES respond to touch from the main Pi screen, so I know that it is functional. It just doesn’t respond when MM runs.
      Does anyone know if there is something I should be adding to the MM config or somewhere else to enable the functionality? I don’t remember having to do this previously, but I may have do so and just not remembered.
      Your suggestions/help is much appreciated.
        sdetweil @CurlyQ12391
        @CurlyQ12391 there is no touch support in the base mm.
        sorry ir frame
        mm has mouse turned off by default
        in main.css comment out the
        cursor:none;
          CurlyQ12391 @sdetweil
          @sdetweil, I was able to find some older posts to enable the mouse so thats functioning at least :)
          I just find it so odd that MM responded to the IR Frame before re-doing everything and now it doesn’t want to cooperate.
          Do you think that MMM-Touch or MMM-touchgestures could integrate the IR Frame into MM?
            @CurlyQ12391 supposedly they take mouse events… (the ir frame is a mouse to the system)
