    Airplay 'Now Playing' module - help badly needed
    16 Posts 8 Posters 15.5k Views 9 Watching
      darrene
      The first step of my module, which simply displays a base64-decoded string in the mirror reads like this.
      /* global Module */
      /* Magic Mirror
      * Module: base64
      * MIT Licensed.
      Module.register("base64",{
          // Default module config.
          defaults: {
                  text: "Hello World!"
        frombase64: function() {
          var string = 'RGFycmVu';
          var decodedString = atob(string);
          return decodedString;
          // Override dom generator.
          getDom: function() {
                  var decstr = this.frombase64
                  var msgstr = document.createTextNode(decstr);
                  wrapper.appendChild(msgstr);
                  return wrapper;
      It seems like it should work, but I get a literal string rather than a value returned…
      A 1 Reply Last reply
      • A
        alexyak @darrene
        @darrene You’re missing parenthesis in your call to frombase64:
        this.frombase64();
        D 1 Reply Last reply
        Reply Quote 3
          darrene @alexyak
          Ah! Thanks so much @alexyak - that’s fantastic. I can now move forwards :)
          So parenthesis are needed to call the function and explicitly not pass it a parameter. Is that right?
            darrene
            So step 2, I have made a short javascript file that will read a fifo file and decode what it sees in the buffer.
            var fs = require('fs')
            var fifo = fs.createReadStream('shairport-sync-metadata')
            fifo.on('data', function(fifoHexBuffer) {
                fifoHexBuffer = fifoHexBuffer.toString();
                console.log(fifoHexBuffer)
            At the moment, the code runs once and stops once it reads. My next task is to have it continue, then I’ll have to make it into a node-helper script, to interact with my base64 decoder/display
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @darrene
              @darrene checkout the file watcher of the nodejs filesystem https://nodejs.org/docs/latest/api/fs.html#fs_class_fs_fswatcher
                darrene
                Luckily there is a fifo-js package available, which makes things super-easy!
                npm install fifo-js
                const FIFO = require('fifo-js')
                let fifo = new FIFO('fifo-testfile')
                var count = 1
                while (count == 1)
                    let text = fifo.readSync(fifo)
                    console.log(text)
                fifo.close()
                I’m getting there. I have an IN and I have an OUT in javascript. Now the hard work of joining the two together - interpreting and the decoding the appropriate metadata begins!
                  darrene
                  So a bit more testing and things aren’t looking as rosy as I’d first thought. Before trying fifo-js, I’d experimented with the filesystem readStream - If i try looping that I end up with a java out of memory condition.
                  The fifo-js approach works with a fifo file that I echo things into to test, but doesn’t return anything while the Shairport service has it open for some reason?
                  There is a metadata reader script which I could use to read the metadata and parse it. I’ve compiled the executable and it runs fine. I should be able to call that from my javascript module through child process, right?
                    darrene
                    Hmm, using a child process doesn’t return anything either :(
                    The shairport metadata reader is a compiled C program which uses printf to return the metadata to the console:
                    pi@raspberrypi:~/fifo-js $ ~/shairport-sync-metadata-reader/shairport-sync-metadata-reader < /tmp/shairport-sync-metadata
                    Artist: "Sohn".
                    Title: "Tremors".
                    ^C
                    But I dont’ seem to be able to parse what’s being sent to stdout from my javascript
                    If anyone has any examples that work, I’d be grateful.
                    jdfraserJ 1 Reply Last reply
                    • jdfraserJ
                      jdfraser @darrene
                      Hi @darrene ,
                      How did you ever make out with your module? I’ve started down the same path, I’m also using shairport-sync but in conjunction with forked-daapd (an airplay server for Raspbian).
                      As forked-daapd can also use mpd commands I’ve been trying to use komponist, which I’ve managed to make return the playing song, album, etc. print out to the console but as I’ve never really done any javascript before am trying to piece together building a module for MM.
                      If you’ve made any progress on your module, I’d love to see it as it may help me finish mine.
                      • V
                        vogelboy
                        I’m just dropping by to express my encouragement for this effort! I would love to have a now-playing module that used the shairport-sync metadata :)
                          A Former User
                          Are there any updates to this module?
                            Brice
                            I’m also interested in the development of this module.
                            I’ve started to recompile Shairport-sync so it can write a plain .TXT file with the metadata each time a new song is detected, now I have to read the last line of this TXT file through a MM-module. But I don’t know if this is the right direction, editing the core of Shairport-sync seems like a bad idea (no updates, etc). I wish I could read metadatas via the pipe in a less complex way. Anyone has worked on this ? Thanks !
                              surekap
                              ANNOUNCE: Check out https://github.com/surekap/MMM-ShairportMetadata
                              Its my first attempt at writing anything in node.js so I basically wrote a python script to translate the XML from shairport-sync into json objects.
                              The module manages a child process which pipes the XML to the Py script and reads the json and displays it.
                                Brice
                                Thanks a lot @surekap for this amazing module. It works !
                                Quick suggestions :
                                • hide the module if no airplay device is connected / no song playing
                                • align text & image on left/right depending on the module position (currently both centered in its container)
                                  surekap @Brice
                                  @Brice changes made. Check out the “alignment” config option.
                                  The hide behaviour is not perfect - takes a few seconds to hide the module - this is because we issue the hide command in case of ‘pfls’ [play flush] and ‘pend’ [play end] metadata commands. Unfortunately, the ‘pfls’ command is followed up with fresh metadata and it takes a few seconds for the ‘pend’ to come from the iPhone.
                                  Tested with playing and pausing repeatedly.
