    Collaboration of MMM-ProfileSwitcher and MMM-pages modules
    9 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @Kostosso
      @Kostosso said in Collaboration of MMM-ProfileSwitcher and MMM-pages modules:
      But I don’t know how should I write this.sendNotification(‘CURRENT_PROFILE’, ‘DESIRED_PROFILE_NAME_HERE’);
      now… that needs to be sent by SOME other module…
      most of those other modules have some kind of config
      remote_control
      alexaControl
      facereco_dnn (altho it uses classes directly like pages, so you wouldn’t need profile switcher)…
      where u can put the notification string ‘CURRENT_PROFILE’
      and whatever data (aka payload) that notification expects…
      now you can ALSO add other classes that can make profile switching easier…
      for me add SAM to the list of classes
      then show modules with classes containing SAM
      that is what the profile module does…
      so, in remote_control is would be ‘CURRENT_PROFILE’,'SAM"
      • K Offline
        Kostosso @sdetweil
        Thank you so much, but I didn’t fully understand where I need to specify
        ['page1']
        ['page2']
        ['pagen']
        and how do I link this definition to MMM-pages modules?
        I realized that I define classes in the header of each module
        module:'MMM-page-indicator',
                classes: 'default everyone',
        Can you elaborate a little more on this or a link where you can read it.
        S 2 Replies Last reply Reply Quote 1
          sdetweil @Kostosso
          @Kostosso i posted it
          pages has a config option
          which has the list of page configurations
            sdetweil @Kostosso
            @Kostosso
            setup your pages config as I had shown
            only one classname in each ‘page’ definition, ‘page1’,‘page2’, etc
            then go to a module definition
            calendar
            what pages do you want THIS instance to appear on
            add those ‘page’ names to the classes list
            repeat thru all the modules in config.
            now profile is a DIFFERENT way of selecting modules
            they take some logical profile name
            by person
            SAM
            MARY
            SUE
            TOM
            so you would add THOSE profile name(maybe more than 1) to the modules you want shown of THAT person (or more)
            suppose u want the family calendar to be shown for both mom and dad and they have profile names that way
            you would add “mom dad” to the classes list for that calendar entry, but not for the kids profiles
            and then u would tell profile switch (via the notification), which PROFILE name to show modules for…
            MagicMirror can only show or hide modules… everything in config.js is loaded EVERY time it starts up.
            • K Offline
              Kostosso @sdetweil
              How and where to use classes: I understood in modules.
              I read a lot of articles in the forum, but never our sample structure
              modules:[
              [ ‘page1’ ],
              [‘page2’]
              And how to apply it in practice, I did not find.
              Maybe there is a piece of the config file where it can be seen in detail (example).
              :folded_hands: Thanks again for your help.
                sdetweil @Kostosso
                @Kostosso
                you won’t find this documented anywhere, its just my idea of making it all better
                i took the sample config (config.js.sample)
                and added mmm-pages
                and used the sample mm-pages config (its only for a few modules) (from the readme.md)
                mmm-pages added at the end…
                only classes: added for the pages defined
                            module: "alert",
                            module: "updatenotification",
                            position: "top_bar"
                            module: "clock",
                            position: "top_left"
                            header: "US Holidays",
                            classes:"page2"
                                        symbol: "calendar-check",
                                        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                            module: "compliments",
                            position: "lower_third",
                            classes:"page2"
                            module: "weather",
                                type: "current",
                                locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                apiKey: "YOUR_OPENWEATHER_API_KEY"
                            module: "weather",
                            header: "Weather Forecast",
                                type: "forecast",
                            module: "newsfeed",
                            position: "bottom_bar",
                            classes:"page1",
                                feeds: [
                                        title: "New York Times",
                                        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                showSourceTitle: true,
                                showPublishDate: true,
                                broadcastNewsFeeds: true,
                                broadcastNewsUpdates: true
                            module: 'MMM-pages',
                                    modules:
                                         [ "page1"],
                                         [ "page2"]
                                    fixed: [ "clock", "weather", "MMM-page-indicator" ], // could have used 'fixed' as a classname here and add that to fixed modules
                                    hiddenPages: {      // same here screensaver and admin classes
                                        "screenSaver": [ "clock", "MMM-SomeBackgroundImageModule" ],
                                        "admin": [ "MMM-ShowMeSystemStatsModule", "MMM-AnOnScreenMenuModule" ],
                • K Offline
                  Kostosso
                  :thumbs_up: Super! Issue closed!
                  THANK YOU SO MUCH!:handshake:
