    Failed update
    10 Posts 2 Posters 1.2k Views 2 Watching
      DarrenHill
      Just tried to update my mirror (running on a Pi3) using the update script and now just getting the RaspiOS desktop.
      In the error log I’m getting this:
      /tmp/start-ae66716a.sh: 1: /tmp/start-ae66716a.sh: ./node_modules/.bin/electron: not found
      /tmp/start-5f9bf958.sh: 1: /tmp/start-5f9bf958.sh: ./node_modules/.bin/electron: not found
      /tmp/start-61e117a4.sh: 1: /tmp/start-61e117a4.sh: ./node_modules/.bin/electron: not found
      /tmp/start-d066481b.sh: 1: /tmp/start-d066481b.sh: ./node_modules/.bin/electron: not found
      /tmp/start-e2a8c45b.sh: 1: /tmp/start-e2a8c45b.sh: ./node_modules/.bin/electron: not found
      /tmp/start-811c1067.sh: 1: /tmp/start-811c1067.sh: ./node_modules/.bin/electron: not found
      /tmp/start-0200e581.sh: 1: /tmp/start-0200e581.sh: ./node_modules/.bin/electron: not found
      /tmp/start-b6c97c53.sh: 1: /tmp/start-b6c97c53.sh: ./node_modules/.bin/electron: not found
      /tmp/start-1e98fa17.sh: 1: /tmp/start-1e98fa17.sh: ./node_modules/.bin/electron: not found
      /tmp/start-e0978d33.sh: 1: /tmp/start-e0978d33.sh: ./node_modules/.bin/electron: not found
      /tmp/start-23891cd1.sh: 1: /tmp/start-23891cd1.sh: ./node_modules/.bin/electron: not found
      /tmp/start-425db6c2.sh: 1: /tmp/start-425db6c2.sh: ./node_modules/.bin/electron: not found
      /tmp/start-4430a341.sh: 1: /tmp/start-4430a341.sh: ./node_modules/.bin/electron: not found
      /tmp/start-be15a75e.sh: 1: /tmp/start-be15a75e.sh: ./node_modules/.bin/electron: not found
      And there is indeed no electron in there, although there is .electron-7jst2j2U -> …/electron/cli.js ?
      pi@mirrorpi:~/MagicMirror/node_modules/.bin $ ls -al
      total 44
      drwxr-xr-x   2 pi pi  4096 Oct  2 17:59 .
      drwxr-xr-x 587 pi pi 36864 Oct  2 17:59 ..
      lrwxrwxrwx   1 pi pi    18 Jul  3 12:40 .acorn-IIB8cHVa -> ../acorn/bin/acorn
      lrwxrwxrwx   1 pi pi    18 Jul  3 12:40 .electron-7jst2j2U -> ../electron/cli.js
      lrwxrwxrwx   1 pi pi    23 Jul  3 12:40 .eslint-UE4ITVWN -> ../eslint/bin/eslint.js
      lrwxrwxrwx   1 pi pi    21 Sep  2  2020 extract-zip -> ../extract-zip/cli.js
      lrwxrwxrwx   1 pi pi    25 Jan  9  2022 js-yaml -> ../js-yaml/bin/js-yaml.js
      lrwxrwxrwx   1 pi pi    14 Jul  3 12:40 mime -> ../mime/cli.js
      lrwxrwxrwx   1 pi pi    20 Apr  2  2022 mkdirp -> ../mkdirp/bin/cmd.js
      lrwxrwxrwx   1 pi pi    23 Jul 25  2021 node-which -> ../which/bin/node-which
      lrwxrwxrwx   1 pi pi    16 Jul 25  2021 rimraf -> ../rimraf/bin.js
      lrwxrwxrwx   1 pi pi    23 Jul 25  2021 semver -> ../semver/bin/semver.js
      lrwxrwxrwx   1 pi pi    21 Jul 25  2021 uuid -> ../uuid/dist/bin/uuid
      Any tips to get things up and running again?
      The script itself seemed to run fine and finished back to the command prompt as expected.
        sdetweil @DarrenHill
        @DarrenHill ok, try the latest… dang pi results different than other OS versons of npm
          @DarrenHill said in Failed update:
          tr
          rerun, I had to fix the order of parms on the npm install
          just updated use force at the end now as 2.21 is installed but not setup
            @DarrenHill just had to fix it again…
            the npm commandline parser is a mess
            it sees this
             "--omit=dev --no-audit --no-fund --no-update-notifier"
            as this
            --omit=    "dev no-audit --no-fund --no-update-notifier "
            grrrrr
              DarrenHill @sdetweil
              @sdetweil said in Failed update:
              tr
              I assume you mean
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
              It ran, but didn’t seem to help. Still got the same in the logs. Also tried “apply force” at the end just in case, no different.
              The script also did display Unknown command: “dev” after each module listing, which may relate to your second post above? An example below - the same appears for all the modules.
              No LSB modules are available.
              doing test run = false
              Minimum Node version: v16.9.1
              Installed Node version: v16.17.1
              No Node.js upgrade necessary.
              Minimum npm version: V7.11.2
              Installed npm version: V8.15.0
              No npm upgrade necessary.
              saving custom.css
              (23) Failed writing body
              upgrading from version 2.21.0 to 2.21.0
              fetching latest revisions
              Unknown command: "dev"
              To see a list of supported npm commands, run:
                npm help
              processing for module MMM-ModuleScheduler please wait
                @DarrenHill ok,I am w grandchild til 7 us Central…
                  No probs, take whatever time you need. Family comes first.
                  If you need any more logs etc, let me know (I’m in the UK, so about for another hour or two but can pick up tomorrow too).
                    @DarrenHill try this update took quotes off the literal
                      @sdetweil Doesn’t look good
                      pi@mirrorpi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/        MagicMirror_scripts/master/upgrade-script.sh)" force
                      force: i#!/bin/bash: No such file or directory
                      force: line 271: --no-fund: command not found
                      saving custom.css
                      npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                      npm ERR! code ENOTEMPTY
                      npm ERR! syscall rename
                      npm ERR! path /home/pi/MagicMirror/node_modules/acorn
                      npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
                      npm ERR!     /home/pi/.npm/_logs/2022-10-02T21_30_31_689Z-debug-0.log
                      added 3 packages, and audited 4 packages in 20s
                      found 0 vulnerabilities
                      processing complete for module MMM-ModuleScheduler
                      processing for module MMM-DigClock please wait
                      up to date, audited 1 package in 827ms
                      processing complete for module MMM-DigClock
                      processing for module MMM-ping please wait
                      added 3 packages, and audited 4 packages in 44s
                      processing complete for module MMM-ping
                      processing for module MMM-network-signal please wait
                      added 3 packages, and audited 4 packages in 3s
                      processing complete for module MMM-network-signal
                      processing for module MMM-Space please wait
                      up to date, audited 1 package in 843ms
                      processing complete for module MMM-Space
                      processing for module MMM-NetworkScanner please wait
                      added 7 packages, and audited 8 packages in 40s
                      processing complete for module MMM-NetworkScanner
                      processing for module MMM-NewsAPI please wait
                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      added 52 packages, and audited 53 packages in 15s
                      2 packages are looking for funding
                        run `npm fund` for details
                      processing complete for module MMM-NewsAPI
                      processing for module MMM-Mail please wait
                      npm WARN deprecated emailjs-tcp-socket@1.0.2: This project is no longer maintained. Please reach out if you want to hop on as a maintainer.
                      added 10 packages, and audited 11 packages in 4s
                      3 vulnerabilities (2 moderate, 1 high)
                      Some issues need review, and may require choosing
                      a different dependency.
                      Run `npm audit` for details.
                      processing complete for module MMM-Mail
                      processing for module MMM-GmailFeed please wait
                      added 50 packages, and audited 51 packages in 7s
                      processing complete for module MMM-GmailFeed
                      restoring custom.css
                      I’m off to bed in a few moments, so feel free to take your time over it. Don’t interrupt your family time for it, it can wait a while.
                      Thanks as ever for the support and effort though.
                          Thanks - that’s fixed it :D
